i posted this before, but have more info. i've installed dashes, the shift console, and set the e-brake cover in place on my 70 frame off. i swapped a muncie into a th400 car. the interior parts all seem to line up ok, so i'm sure that the shift console is positioned properly. i've shimmed the shifter mounting bracket with 2 washers (that's all i could squeeze in) and the shifter still hit the cover. then i changed the linkage to the short-throw holes, and now have clearance in 1st and 3rd, but not in reverse. it looks as though i need at least 3/8" more room. the body has about 1/2" clearance to the bell housing, so i can't move the body forward. any ideas?
I also swapped out a Th-400 for a 4 sp. Had the same problem with the 1-3 shifter. Turned out that the linkage was loose at the transmission. Not sure if that's your problem but thought I would throw that out there.
I had this problem after a frame off restoration. After I checked the linkage and position of the shifter on the transmission was done to the chassis manual specs I found the bottom of the dash had some cables and wires holding the console to the rear of the car. I was able to move the console forward to fix the problem.
I have a similar issue with my Richmond 5 speed. The shifter is very close to the front of the console hole. I've debated about getting a shifter handle that has a 15 degree tilt to move it back some. I think the problem lies in how the shifter is mounted. Most of the manuals today have the shifters mounted on the transmission. I've seen some figures that show the original shifters in C3's being mounted off the x-member which probably set them back just a hair. Good for vibration isolation, but I don't think it does much for performance.
The rev rod has a threaded connection at the lever (arm), unhook the lever from the trans and rotate it around the rod to move it fore or aft as needed. The 1-2 and 3-4 have a little diff set up as you can see in the pic but still allow for the same adj.
Just dawned on me, it appears to be the same set up as the clutch rod.
Hi
If you have clearance for 2-4 shifter and not for 1-3-R you should re- center the shifter handle by adjust all the shifter linkages in away that the center point of the handle will move back.
The center point is the point you can move the handle right to left freely.
Avner
Hi
Avner
Why not just adj the rod, you can see the set up in my pic for the 1-2 and 3-4, it is a little diff than the rev but still lets you move 1-2 and 3-4 independantly so you do not have to fiddle with the shifter.
avner
it's been a while since i installed the shifter to the bracket, but i believe that i remember that the shifter doesn't have any mounting adjustments, and that the centering of the shifer is limited by the non-moveable portion of the shift mechanism. this limits the ability of moving the shift lever back and readjusting the control arms. am i wrong, or am i having a senior moment?
jeff
Fevre: I don't think you have mach play without moving from center point but it's good to try this before he play with all linkage rods.
jnb5101: I had the same problem after the restoration and that what I did to solve the problem.
You right the bracket doesn't have any adj' only the linkage rods
has threads at the end to adj'.
thanks, again, everyone
the problem is that since the shifter is attached to the bracket and can only be tilted back by shimming the two front mounting bolts, and the alignment "tool" is inserted into the slot in order to operate properly, the lever is fixed in only one position in relation to the car/body/console. then the linkage rods are set to the trans, so they can't arbitrarily set to move the shift lever backward. i just don't see any way to gain clearance except by moving the shift console forward. and since it's already jamed under the radio, and the parking brake cover fits properly between the metal brace that makes up the rear of the seat area and the back edge of the sifter console, i'm at a loss as to where i can find any room.
Check for wires or cables in front of the radio holding the console from going forward. The bottom of the dash should move a little and give you a little more room on the front side of the shifter hole. This fixed the same problem on my 73.
thanks again
i've checked for wires and other obstructions and couldn't find any. i even elongated the notches on the console that the two studs on the bottom of the gauge bezel fit into. still no room. i guess that my only option is to grind out a section of the shift plate and dress it up cosmetically as best i can. call me bubba!
jeff
