Help..New 73 Stingray Owner
It was at a shop for a major tune up and the mechanic suggested the timing chain needed to be replaced. Had the timing chain replaced and no more issues.
Did you check the timing yet??
When you get everything running great... invest some money and get a holley! I cannot tell you how much I hate the Rochester Quadra-junk
Roger
many love them, okay,
many hate them, okay,
like many, i've had both; whatever is desired results can be obtained by proper tuning on correct core.
Just ask Lars.
They're only "junk" if you don't understand them.
follow 73jst4fun & RMS73 suggestions,
start with overall inspection, replace vacuum lines, hoses, etc.
get the mechanical and vacuum advance set and working,
then move to carb adjustments; choke adjustments can be a little aggrivating. i end up with one setting for summer and one for winter (or using the summer setting all year, but requires pedaling some).
if carb has brass float, replace with phenolic.
use the search to find links to papers on these subjects.
get a copy of the factory shop manual and assembly manual (AIM) as soon as you can. good luck . . .
I will restor the interior in the winter. Guys..what should this cost? Seat covers, seat backs, dor panels, carpet, minor trim and weatherstriping.
