Bellhousing alignment question
Old Jul 26, 2007 | 07:47 PM
carriljc's Avatar
carriljc
Default Bellhousing alignment question
I am preparing to align my bellhousing and after reading a bunch of old threads I'm kinda confused. Here are my direct dial indicator readings:
3 o'clock = 0
9 o'clock = .0095
delta = .0095
12 oclock = .002
6 o'clock = .007
delta = .005
Can I use the .007 dowel pins to correct his misalignment?
Old Jul 26, 2007 | 08:10 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You are offcenter less that .005" you are good to go the way it is
Old Jul 26, 2007 | 11:11 PM
carriljc's Avatar
carriljc
Default I thought so too....
but my tranny is really hard to insert, and the engine drags the input shaft in neutral.
My starter gap is good, I've changed throwout bearings, installed an adjustable pivot ball, and I even replaced the forward bearing on the Richmond ROD.
Old Jul 26, 2007 | 11:35 PM
MotorHead's Avatar
MotorHead
Normally if the tranny is hard to insert, you connect the linkage and drepress the clutch, this allows the clutch disk to center itself and the tranny should now slide in easily.
Have you checked the condition of the pilot bearing ?
What I am getting is you think the motor is spinning the tranny input shaft with the clutch depressed ? I doubt it is the pilot bearing, or an alignment problem with your runoout specs. Sounds more like the clutch is not disengaging for one reason or another.
How are you checking runout, are you running the dial indicator inside the bellhousing opening for the tranny or outside on the mating surface ?
Old Jul 26, 2007 | 11:48 PM
...Roger...'s Avatar
...Roger...
How far did you drive the pilot into the back of the crank.If you drove it in flush there is a good chance the inside end of the pilot is smaller now. If it is smaller it will gauld the input shaft.I have gotten in the habit of leaving the clutch out and trial fitting the trans and then putting the trans in a gear and rotating the output shaft to make sure it turns smooth.Then I put the clutch in bolt it all up and push on the clutch and turn the output shaft and see if the clutch is releasing and rotating smoothly.Its extra work but its worth it.
Old Jul 27, 2007 | 12:51 AM
carriljc's Avatar
carriljc
Default It stops making a racket when I depress the clutch..
And when I let it back out, it starts dragging. When the car is cold everything is nice and quiet...once it warms up, the noise starts...that's why I suspect a tolerance issue.
I have been installing the pilot bushings to the "flush" condition. Is that improper? I've changed pilot bushings 3 times, changed the throwout bearing once, and as I mentioned before; even changed the forward bearing on the tranny.
I took 3 sets of readings with the dial indicator....I run the dial indicator on the inside the bellhousing opening.
I was reading some old posts and I saw that some tranny manufacturers want a maximum .005 total.....I guess I'll try to attain that.
SO, I just ordered a pilot "bearing", how far should I insert it? I'm going to align the bellhousing since I'm already halfway there and I'm getting tired of pulling this tranny.
Old Jul 27, 2007 | 01:57 AM
Z-man's Avatar
Z-man
Flush should be fine...
Old Jul 27, 2007 | 09:08 AM
...Roger...
OK this is not brain surgery BUT it is a bit of an Art to set these things up especially when the parts are not factory matched.In other words when you combine parts from several vehicals and throw in some aftermarket ones.This is why I feel it is nessicary to preinstall the trans. without the clutch assembly.Yes the trans. is heavy but I feel lifting it 2 times beats a dozen or so.
On the pilot I usually leave them out by about 1/8".But you need to measure the depth of the bore.Nothing special needed- a pencil with no eraser will work-slide it in to the bottom of bore-put your finger on the pencil to mark depth and compare to length of pilot bushing.Mark this depth on pilot and only go in this far.Too far will crush end of bushing and make bushing too tight on input shaft.The pilot bushing is around .800 long,I see bore depths of only .650 about 20% of the time.(auto trans. crank? hmmm)
In your first paragraph you talk about dragging-please explain more.
Old Jul 27, 2007 | 11:11 AM
carriljc's Avatar
carriljc
Default What I mean by "dragging"....
First of all, thanks for all the info....
What I mean by dragging is that when the car warms up it appears to start "dragging" the tranny input shaft ...and yes, the clutch is disengaged.....that's why I'm suspecting a misalignment condition.
Anyway, as far as the pilot bearing/bushing insertion issue; is the bore tapered inward at the forward end? Is this what you mean by crushing the bushing? What is it that I accomplish by measuring the depth? It seems that the bore ends, and there is an open area ahead of it.
I will measure the depth, and not insert past this point, however; what is the most that would allowable to extend aft of the bore surface? 1/8"? 1/4"?
Old Jul 27, 2007 | 11:16 AM
carriljc's Avatar
carriljc
Default Pilot Bearing versus Pilot Bushing question...
I ordered a pilot "bearing"...I've never installed one of these units. Is there a different strategy than installing a pilot "bushing"? I don't want to damage it; do I just find and adequate socket and tap it in?
Old Jul 27, 2007 | 12:30 PM
...Roger...
I dont have a problem leaving them out a 1/4".
Taper? no taper just the end of the bore -but there is not a tall lip so you can drive it in further and it would act like a taper.
Crushing-the end towards the engine outside ID is reduced thereby reducing the inside ID and squeezing the end of the input shaft-causing it to "drag" and eventually gaulding the tip of the shaft.
I think you said your tranny went in "hard"-(with more resistance than you think it should)what we are talking about "could" cause this but also dragging(slow clutch wind down time-12 seconds at the most)can be caused by the clutch not releasing properly.
I dont care for pilot bearings.If you are having alignment issues it will make it worse and could destroy your input shaft.
Old Jul 27, 2007 | 02:09 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Maybe I'm not getting your #'s right, but why not use the 0.007" dowels to achieve 0.002" from concentric"?
Old Jul 27, 2007 | 02:30 PM
gkull's Avatar
gkull
The .007 offset would really get you in close. Like within a few thousands. IMO - long dowel pins are the way to go
http://www.jegs.com/webapp/wcs/store...51799_-1_11495
Old Jul 27, 2007 | 02:37 PM
glenn64vette's Avatar
glenn64vette
I do the same thing
Old Jul 27, 2007 | 06:31 PM
carriljc's Avatar
carriljc
Default I will do the pre-fit....
before installing the clutch.
I ordered the alignment dowels, so I should be able to get really close. I also ordered a pilot "bearing"....never wanted to use one before...I thought perhaps I could use one if I was able to get my specs really tight.
I can eat that cost, do y'all recommend I just get pilot "bushing"?
I will also measure the depth of the bearing support surface and not go too deep. I just finished removing my old pilot bushing...had to destroy it to get it out. Tried 2 different pilot bearing removal tools...one didn't fit and the 2nd one couldn't pull it out. I suspect the 2nd one may have just been worn out...didn't have much in the way surface lip to grab the inside edge of the old pilot bearing.
Old Jul 27, 2007 | 07:36 PM
Desertvette's Avatar
Desertvette
Default Tight pilot bushing
I've run into pilot bushings being too tight with 327 crankshafts that were used with automatic trannies. If you have to wail away to install the bearing ,it's too tight and compressing the bushing which is whats making it tight on the trans input shaft. Go to Rock Auto and look up pilot bushings under 67 corvettes and you will find an undersize bushing that may cure your problem. Dorman part # 14651. It has a .593 inner diameter and an outside diameter of 1.060 about .030 than normal. LOL
Bob
Old Jul 27, 2007 | 08:38 PM
carriljc's Avatar
carriljc
Default Dorman 14651???
That might be the hot ticket.
Something got lost in the last message; am I to understand that the outside diameter of this bushing is .030 inches "smaller" than a regular SBC pilot bushing?
To Bellhousing alignment question
Old Jul 27, 2007 | 09:19 PM
Desertvette
Yeh ,the word "less". Sorry. I had this problem and my machinist installed one of these bushings. Saved the expense of machining the crank. Found them latter online at Rock Auto if needed again.
Bob
Old Jul 28, 2007 | 11:11 AM
carriljc's Avatar
carriljc
Default I saw the "lip" inside the pilot bushing hole...
Funny that I hadn't seen that before.
SO I'll do the following:
1. get the pilot bushing with the smaller outside diameter as recommended above, measure the depth to the lip, and not insert any further than that depth.
2. index the bellhousing since I already pulled the old dowels and ordered the new ones.
3. prefit the tranny before installing the clutch and check that it turns smoothly.
.....also, from the feedback here, I really should NOT use the pilot "bearing" and just use a bushing.
Any other recommendations?
Old Jul 28, 2007 | 11:49 AM
...Roger...
Sounds Good
One thing to note concerning the smaller bushing.If you dont have a set of calipers to measure the bore ID then buy both size bushings just in case the smaller one is too small.
