Vacuum & Timing Setting...Help!!
Old Jul 28, 2007 | 01:55 PM
ddale1977's Avatar
ddale1977
Default Vacuum & Timing Setting...Help!!
Trouble with my timing.
First, I rebuilt my 77, 350 auto. Mild cam, vortec heads, stock bore and stock cylinders, eldelbrock intake, Q-jet (rebuilt by Lars), 2500-3000 stall.
Car idles good at about 800.
Here are my problems.
1. I put a vacuum gauge on the carb where the distributor vacuum hose would go. I only get about 12 on the gauge. Is that the right place to check for vacuum? I was thinking I needed about 20? I unplugged all other vacuum hoses from the carb and plugged the carb port. I also unplugged the two lines from the fitting on the manifold and plugged the fitting. No change in the vacuum. Do you think I have a leak? Does a cam cause lower vacuum?
2. I go to set my timing. Started out at 12*. Then brought it up to about 3000 and adjusted to 36*. It is all in at 3000. But.....when I go back to check my base, it is 22* (yikes) I drove the car around the block and it ran fine as far as I could tell. Got any ideas what I am doing wrong?
Doug
Old Jul 28, 2007 | 04:21 PM
ddale1977's Avatar
ddale1977
Update on Timing.
I have 15* at idle and 36* at 3,000 rpm (all in). I didn't realize that my idle had gone up signficantly when trying to adjust (wife was in the car and didn't tell me).
But...when I hook up the distributor vacuum advance, it takes it to 55*...which I know is too high.
I have an AS-20 advance. I'm thinking it is an adjustable but I can't find any info on it Heading to Napa to see if they have a 15 or 16 * advance unit.
Hoping that does it. Any feedback? Am I way off on this?
Doug
Old Jul 28, 2007 | 04:41 PM
SmokinBBC's Avatar
SmokinBBC
Originally Posted by ddale1977
Update on Timing.
Doug
Your mechanical looks good.
I don't know what an AS20 is but if the 20 is the amount of advance, then it does look like too much. I think for your year the stock lower HP cars (165HP?) had an 18 can and the higher HP car(205HP?) had a 15 can. You not want to go higher than 52 total. There is a sticky post at the top of the tech forum by BarryK that has really good info.
Here it is:
http://forums.corvetteforum.com/show....php?t=1430339
Old Jul 28, 2007 | 05:40 PM
ddale1977's Avatar
ddale1977
Thanks for the reply.
Here's another update. I found out the AS-20 is an 'adjustable' can. I adjusted it so I now have 52* total combined (yippe finally).
Now....can anyone help me understand my vacuum question. I connected it to the port where the distributor vacuum advance goes (one the carb). Reading only about 12-13 at idle. Am I supposed to have more vacuum at idle?
When I hit the gas, it drops to near zero and then up around 20 or so....then back to 12-13.
The car idles fine. Starts fine. Seems responsive.
Who can educate me on my vacuum?
Doug
Old Jul 28, 2007 | 06:02 PM
jotto's Avatar
jotto
A cam will change your vacuum. A 'bigger' cam will reduce your vacuum readings. I dont know the whys but it will. Some guys who have really big cams install vacuum pumps.
Some more knowledgeable peeps will chime in.
If you have the timing set and your brakes work well, you will probably be ok.
Old Jul 28, 2007 | 06:11 PM
ddale1977's Avatar
ddale1977
Thanks for the reply. I'm no expert at reading a cam card. My machine shop recommended this cam. Comp Cam Part # 12-246-3
At the bottom of the card, it says,
DURATION @ .050 INTAKE 230, EXHAUST 236
LOBE LIFT INTAKE .3270, EXHAUST .3270
The car certainly sounds good with it. Hope its a decent cam.
Doug
Old Jul 28, 2007 | 09:30 PM
R96IMP's Avatar
R96IMP
Thats a real healthy cam,.490 lift and 230/236 duration.Try adjusting your carb mixture for highest vacuum reading at idle and you'l be surprised at what it'll feel like then reset your timing,and idle speed.You might get 15" vacuum out of it.
That cam will pull to near 6000 with a good intake and good exhaust.You got a HOLLEY?
I hope you got a 4 speed or a looser converter.....It'll want to creep on you at lights.
Old Jul 28, 2007 | 10:03 PM
ddale1977's Avatar
ddale1977
Yes, I have a looser converter. ...Hughes 2,500
I'm running my Q-Jet (rebuild by Lars). I realize there is a love/hate thing with Q-Jets.
I'll try to adjust the idle mixture tomorrow to see if I can get any more vacuum. Thanks for the advise.
Thanks,...Doug
Old Jul 28, 2007 | 10:21 PM
Bullyj's Avatar
Bullyj
That seems about right to me I don't think your gonna be able to get any more vacuum at idle. Of course there are alot better tuners than on here.
Old Jul 29, 2007 | 05:45 PM
Blue79's Avatar
Blue79
Someone please correct me if I'm wrong but don't you check the vacuum below the throttle plates(manifold vacuum)? The place you describe your vac hookup and the question you posed may be above the throttle plates at a ported vacuum nipple. I don't think you're going to get the results you're looking for on a ported vacuum supply.
Old Jul 29, 2007 | 09:07 PM
77BuffaloVet's Avatar
77BuffaloVet
If it runs well with 36, keep it there, however I have more power retarding it back to 32 all in by 2800. That leaves me with 18 at idle and 14 mechanical advance. With vaccum advance hooked up I am at 48 total timing, which is nice and safe for cruising.
On your vaccum, 12 is pretty good. I have 14 at idle. Tune it for highest idle, but as long as everything works, ie headlights and such you are in good shape.
Good Luck!!!
Chris
Old Jul 30, 2007 | 07:51 PM
ddale1977's Avatar
ddale1977
Thanks for the advise guys.
My carb right now is set to 5 & 1/2 turns out. Lars told me today that it was very likely too much....so Ill try again for the highest vacuum or idle in the next day or so and see if it makes much difference after a test drive.
May play with the distributor springs and timing to see if I can get all in a 'little' sooner than 3K....I think?
Doug
To Vacuum & Timing Setting...Help!!
