Por15 ??
Old Jul 28, 2007 | 02:31 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Por15 ??
OK, I have blasted my passenger door frame, got all the innerds and skin striped off of it, got some cheesecloth in a few places so I got to fix those. Should I primer the areas that are going to get POR15 before painting them?
clean blasted bare steel
Old Jul 28, 2007 | 02:56 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
This should help in your decision. Good luck with your project!
http://www.por15.com/
Old Jul 28, 2007 | 03:23 PM
SIXFOOTER's Avatar
SIXFOOTER
Thanks Jud, got that answered
Old Jul 28, 2007 | 04:08 PM
guitarcrazy02's Avatar
guitarcrazy02
From what I've heard, POR-15 doesn't stick to clean surfaces. I think you want to scrape off the dirt and flaky stuff, and then apply it right on top of the rust.
Old Jul 28, 2007 | 04:34 PM
SIXFOOTER's Avatar
SIXFOOTER
on their site it says basically the same thing, clean and prep, then paint, no primer
Old Jul 28, 2007 | 04:40 PM
kaiserbud's Avatar
kaiserbud
POR-15 says if bare metal to clean with their solvent, then etch with their product. If a surface rust appears afterwards, it is ok - as POR-15 likes that. Do not use any other primers/paints under the POR-15 as it does not bond to those surfaces. Maybe POR-15 has a primer - but I do not recall.
It's funny... POR-15 stuck to the floor of my garage and only god knows what grease and crap is on that floor ! -
Oh - and wear gloves and DO NOT get it in your hair.
Old Jul 28, 2007 | 04:46 PM
mrvette's Avatar
mrvette
Too boot some years ago, someone said use a garden sprayer for inside frame/etc....
that tschit will not spray, and I wound up with one HELL of a mess.... it's so bad, I refuse to use it anymore....
Old Jul 28, 2007 | 05:06 PM
stpman's Avatar
stpman
I've seen it peel off in sheets where it was painted over clean metal
Old Jul 28, 2007 | 06:34 PM
Joe45's Avatar
Joe45
Maybe I am old school but I just can't figure out how a coating can work with rust to stop it. On bodies and frames rust starts from the inside and goes outwards, or so I thought. I prefer the following...
A good sandblasting
2 coats of either epoxy or Zinc enriched primer
2 coats of black for a topcoat.(epoxy if not exposed to sunlight)
Just did my frame this way. Looks great and I suspect it will last a long time. Surely won't be driven in other than sunny days. Birdcage is next.
Old Jul 28, 2007 | 08:42 PM
SIXFOOTER's Avatar
SIXFOOTER
I might put a layer of fiberglass on the inside bottom of the door. Got a few holes rusted in it and I want it waterpoof. That metal ready is just an etcher, so either glass or etcher and por15.
suggestions?
Old Jul 28, 2007 | 08:55 PM
72LS1Vette's Avatar
72LS1Vette
Check out www.rustbullet.com also. I have used it on 2 frames and it sticks to bare metal as well as rusted without any additional surface prep other than the usual degreasing and cleaning. I wouldn't try spraying it since it would be very very very bad to inhale any of this stuff. Both RB and POR cure by absorbing moisture from the air so if you inhale some it will cure immediately inside your lungs.
Rick B.
Old Jul 28, 2007 | 09:28 PM
SIXFOOTER's Avatar
SIXFOOTER
Yea, I painted the frame with POR15, but did it outside
Old Jul 28, 2007 | 09:44 PM
Red 69's Avatar
Red 69
suggestions?
I like to use POR 15 when I want a gloss finish on a frame or gas tank. Problem is, it is expensive and has a short shelf life. Also, the surface needs to be preped per instructions.
I am biased toward PPG epoxy primer and have been using it quite awhile. It has a much longer shelf life, costs about the same, $60/ qt. If you use the black color, it comes in many colors, you will find many uses for it. It sticks to most anything, as long as there is a solid surface and without acid etching. You can apply bondo over it, or just about any other sealer or adhesive. It is a primer, so it will take paint over it. I seldom top coat it as with a little extra catalyst it has a nice semi gloss finish. I don't sell the stuff, but do like what it does. And it can be brushed on.
I do like the POR 15 when I need a gloss finish and rust protection, but in your situation you might consider the PPG DLF. You might also check over on the paint and body forum for an opinion.
Old Jul 28, 2007 | 09:52 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Use POR on rust and not on clean metal. Any primer sticks better to clean metal then por.... I ordered the por test package for $15 and used it on rust and on clean metal.... I scraped it off my windshield frame because it came off too easy... on rusty parts it's better than anything else...
Before I used the por red69 told me to get some PPG epoxy primer instead....... should have listened.....
Old Jul 28, 2007 | 10:51 PM
stpman's Avatar
stpman
Something else to remember if POR15 is left exposed to the sun (without top coating) it will go chalky and lose its gloss.
Steve
Old Jul 28, 2007 | 11:29 PM
SIXFOOTER's Avatar
SIXFOOTER
I ended up useing the POR15 on all the surfaces that I had rust issues on, had a little primer on it. Looks good for now. Tomorrow I'll tackle the weld on patches. Only tough one looks like the upper rear corner pn the pass door. But I think I can get it done.
Old Jul 29, 2007 | 05:46 PM
superdad60's Avatar
superdad60
Also if you don't use it all and plan on saving some...
Either clean the can or use Saran wrap on top before you put the lid on or it will be the last time you open the can.
Trust me!
Old Jul 30, 2007 | 09:17 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
POR 15 sprays just fine when thinned right, brushed it on parts and sprayed frames ( and firewalls with the stuff. but you do need to follow thier reccomendations
limitations are
1. uv sensitive, will need to top coat if exposed
2. lid needs to be closed tight when done or it turns into a chuncky goo
3. you need to use their metal ready to clean if using on bare matal, or treat metal with a self etching primer first (yes this does work with POR 15 )
4. wear gloves cause it will stay on your skin ofr a week or so
expensive stuff but works as advertised when instructions are followed, there are other opstino though
check out the Eastwood Company
cheers
tim
To Por15 ??
