stearing column problems
Old Jul 29, 2007 | 01:53 PM
jagan's Avatar
jagan
Default stearing column problems
Just assembled my 68' telescopic column and the upper bearing and small shaft can be pulled up about six inches when the lock ring is tight. Is this column broken or am I doing something wrong? Any help would be great!
Old Jul 29, 2007 | 03:12 PM
Jim Shea's Avatar
Jim Shea
There should be a small semi-circular wedge and a 12.5 inch long rod inside the upper steering shaft. The star screw should push directly againt the rod and the wedge should tip and lock the upper steering shaft to the lower shaft.
The following are three scans from the Chevrolet Shop Manual on the 1968 telescoping column. Note that the rod and wedge are shown on the blowup in scan #2.
http://jimshea.corvettefaq.com/wp-co...67-68Scan1.doc
http://jimshea.corvettefaq.com/wp-co...67-68Scan2.doc
http://jimshea.corvettefaq.com/wp-co...67-68Scan3.doc
Jim
Old Jul 29, 2007 | 07:59 PM
jagan's Avatar
jagan
the lock ring to lock the column from telescoping is tight and the column slides as well- now I have two problems. I will look at the docs and try to figure it out-- Thanks!
To stearing column problems
