Gear shift not engaging
Old Jul 31, 2007 | 10:26 AM
noel48's Avatar
noel48
St. Jude Donor '14
Default Gear shift not engaging
4 speed,would not go into any gear but 4th.Lever is limp.Any ideas?
Old Jul 31, 2007 | 10:32 AM
1fastC3's Avatar
1fastC3
how so? does it flop around like a wet noodle? if so you may want to check the mounting bolts that hold the shifter in place. Its happened to me once before after a lot of highway driving, lock washers were the cure. Good luck.
-alex
Old Jul 31, 2007 | 10:46 AM
noel48's Avatar
noel48
St. Jude Donor '14
Yep,like a wet noodle.Do I have to remove the rubber casing to get to the bolts?
Old Jul 31, 2007 | 10:50 AM
GDaina's Avatar
GDaina
the bolt that holds the shifter handle is loose.
Old Jul 31, 2007 | 10:51 AM
GDaina's Avatar
GDaina
Yes, the rubber dust boot...
Old Jul 31, 2007 | 11:00 AM
noel48's Avatar
noel48
St. Jude Donor '14
Will check it out.Thanks guys
To Gear shift not engaging
