Ok, I have a 1980'ish rear end and have it all apart. I have 2.96 gears in it now, but would like to go a little bigger. Will this fit? If not, what do I need to be looking for. Only 3 hours left. Thanks.
Is your vette an automatic? You're going to lose some of your top end going up to 3.70, you'll be at 5,000 RPM's at 60 Mph. I'm doing a 700R4 transmission in mine - that combination lets you gain the benefits of those gears without having to work the motor so hard on the interstate.
If yours is a manual you might be OK - you're still going to lose some of the top end, but it won't be as bad with a 4 speed manual as it would be with a 3 speed auto.
