Headlight problem
Old Nov 3, 2001 | 02:34 AM
C3sharkattack's Avatar
C3sharkattack
Default Headlight problem
I think my headlights developed a vacuum leak. The headlights will not come up all the way, they come up halfway and then I have to pull them up the rest of the way. So what I want to know is if there is a conversion kit that can convert the headlights from vacuum controlled to electronic controlled.
Old Nov 3, 2001 | 02:35 AM
QuickVet's Avatar
QuickVet
Default Re: Headlight problem (C3sharkattack)
never heard of such a thing. most people rebuild those canisters up front or something. i need to do it soon too. :rolleyes:
Old Nov 3, 2001 | 03:22 AM
bluevette's Avatar
bluevette
Don't know about the electric setup, but before you go changing your whole headlight system, check out one of our forum member's (AJ) web site. I've met him, he's a great guy and very knowledgeable about vacuum systems on our C3's. He has lots of great information on there and could probably help you solve your headlight problem.
http://members.home.net/awsvette/
Good luck.
John
[Modified by bluevette, 10:24 PM 11/2/2001]
Old Nov 3, 2001 | 08:26 AM
BLT-71's Avatar
BLT-71
Check as many vacuum lines and there connetions. It sounds like a small leak that is not allowing enough vacuum to reach the lights.
I had a similar problem and it was a small line had slipped off the resevoir tank.
To Headlight problem
