Tire clearance issues!!! Please help!
Old Aug 2, 2007 | 09:25 AM
EDDIE DEXX's Avatar
EDDIE DEXX
Cruising
Default Tire clearance issues!!! Please help!
I have a '69 convertible with standard 15x8 rallys. I installed longer bolts between the trailing arms and leaf spring to avoid the 4 wheel- drive look, now unless I set the camber way out the leaf spring digs into the tires. This is the case with a mono leaf spring and a new 7 leaf traditional spring that I just purchased. I know one answer is to install tires that are not as wide but that brings me to my next issue; I just purchased a new set of Coy's wheels and since they are having production problems with 18x8's, they sent me 18x9.5's for the rear. The problem now is that the leaf spring will accually rub the rim instead of the tire. Any ideas???
Old Aug 2, 2007 | 10:37 AM
rcread's Avatar
rcread
I bought a fiberglass rear spring from Van Steel that is shorter than the stock spring. This allowed the spring to clear the wheel.
Old Aug 2, 2007 | 12:43 PM
EDDIE DEXX's Avatar
EDDIE DEXX
Cruising
Thanks for the info. I guess that means I have 1 steel and 1 fiberglass spring for sale.
Old Aug 2, 2007 | 12:54 PM
Jim_Harrison's Avatar
Jim_Harrison
I ground about 1/2 inch off the ends of my TRW fiberglass spring. You should be able to grind off some of the ends of a steel srping. I'm not sure how much, you need to be careful that it isn't too thin.
Old Aug 2, 2007 | 04:35 PM
68 NJConv 454's Avatar
68 NJConv 454
with both.
Quick fix is to shorten the spring.
There are a few threads on here showing how members have shortened their own spring but I would rather purchase a new one and sell the old ones.
I beleive you can go 1/2 shorter or 1 full inch shorter on each side. You don't want the bolt angle too drastic so choose wisely.
If the bolt just hits the rims on the coys then go maybe a 1/2 or 3/4 of an inch shorter. Talk to Van Steel or VBP and they'll help ya out.
Old Aug 2, 2007 | 11:35 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine fit no problemo 18 x 9.5 with 5 inch backspace. The spring goes inside the rim and even the long spring bolts are an inch away from the tire.
One more thing, the parking brake cable tab on the trailing arm seems to fit inside the rim too
What is the backspacing on your 19 x 9.5 rims ?
Old Aug 3, 2007 | 08:37 AM
EDDIE DEXX's Avatar
EDDIE DEXX
Cruising
Your spring in the picture has much less arch than my mono leaf or my new 7 leaf. My rims have 5" backspacing as well, if the ends of my spring were even 1" higher I think they would clear. There is about 3/4" that I can cut off each side but that isn't going to give me the clearance I need to set the camber where it should be. I know it's probably a very bad idea but my lack of patience makes me want to heat the ends of the spring and bend them ever so slightly. When you guys are saying shorten the spring I assume that you mean to drill additional holes to move the bolts further in. Correct?
Old Aug 3, 2007 | 10:24 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Shortened Springs
Our rear fiberglass springs are made 1" shorter than stock. Typically this is enough for the basic wheel and tire upgrade. However, if you really want to go larger, we can shorten the spring an additional 1". We do not recommend you go any shorter.
We manufacture many different arch styles and spring rates for all Corvette generations. Depending on any mods you have done, the weight of your car and what you hope to accomplish, we can fit you in just the right style and rate. Please just give us a call and we can discuss your project. You can email me directly at pattie@VBandP.com or call me toll free at 1-800-237-9991.
It is best to have the spring shortened when it is made. When you shorten them later, it changes the rate and the spring looses it's integrity. Also, heating it or grinding it, will void your warranty. Our fiberglass springs come with a 5 year warranty. I agree with one of the above posts, put your springs for sale on the forum or ebay and purchase some new ones. We offer Corvette Forum members a 10% discount off of our products.
Pattie
VBP
Old Aug 3, 2007 | 12:22 PM
68 NJConv 454
There ya go!
I dealt with Pattie for all my performance suspension products and she was great.
Old Aug 3, 2007 | 01:05 PM
MotorHead's Avatar
MotorHead
VBP = Vette Brakes & Pattie
Old Aug 3, 2007 | 05:11 PM
VBP's Avatar
VBP
Thank you guys.
:o
Seriously, please call us toll free at 1-800-237-9991. You can talk with Gary and I am sure he can help you out.
Pattie
VBP
To Tire clearance issues!!! Please help!
