'80 vs. Pre '80 leaf spring length
Old Aug 2, 2007 | 05:03 PM
Dead End Kid's Avatar
Dead End Kid
Default '80 vs. Pre '80 leaf spring length
Does anyone know the difference, assuming length, between an '80 spring and an earlier spring. Some of the current posts got me thinking about what actually is wrong with my '80.
The good members of this forum helped me determine that I have an earlier rear end then what came in an '80...(no bat-wings/etc). When I got the car it sat high in the rear, and road/rides like a buck-board. The first thing I tried was to change the spring, and of corse, I asked for an '80 replacement. Nothing changed...ride height still was wrong and I still had to add spacers to stock ralley wheels to keep the spring from rubbing the tires...And yes, I have gone the longer bolt route. This still didn't make sense as everything is stock, plus ride quality still sucks.
Any chance that the spring, being an '80 could be the bain of my existance
Old Aug 2, 2007 | 09:11 PM
mapman's Avatar
mapman
Originally Posted by Dead End Kid
... The good members of this forum helped me determine that I have an earlier rear end then what came in an '80...(no bat-wings/etc). ...
You are saying that someone replaced the Dana (aluminum) differential and carrier with an earlier (steel) carrier?
Is the frame original to the car?
The standard rear leaf spring for 1980 had nine leaves, and the width of the leaves was 2.5 inches.
edit:
1963-1976 Rear Spring was 2.25 inch wide.
1977-1982 Rear Spring was 2.5 inch wide.
Old Aug 2, 2007 | 09:54 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
i currently have the spring off of a '79 on my '80.
did the swap myself, so i feel safe in saying that they are the same width - width being defined as end to end. no change in ride height even though the '79 spring was taller (more leaves). i assumed it might be a gunkamaya ( or whatever ) suspension. longer bolts on the carrier and i was off and running.
the only other difference i noticed was that the carrier on the '80 used three bolts and a triangle keeper as opposed to the 4 bolt, square keeper of the '79 (and steel/cast vs. alum). no effect on the spring. no change in ride height.
Old Aug 3, 2007 | 12:34 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Good question, it's not a one-for-one swap & I'd think it would be too painful a mod. (not to say bubba wouldn't do it) A picture would be great.
BTW there's a good 79 spring for sale in the For Sale Section.
Old Aug 3, 2007 | 10:31 AM
Dead End Kid
Thanks for the responses. I guess I'm going to have to get over my fear of camaras and posting pictures. It is my assumption that the frame got replaced somewhere along the way as there are no signs of bubba's and the rear end-in general, looks like...well...only the General (motors) has been there previously. Hopefully one day I'll figure it out. Got a feeling by the time I do I'll be able to hang a shingle as a full-blown proctologist. (SP)
To '80 vs. Pre '80 leaf spring length
