Stroker Cam And Heads Question
My Vette is getting a 383. I am not sure what cam to install in the motor. But before any of you answer this question, you will need to know some of the information about my Vette.
It has;
3.70 rear end gears
Automatic transmission ( I will install a high stall converter)
Transgo shift kit installed in said transmission
The heads are World Products S/R Tourquer heads good for valve lift up to .560, 170cc intake ports, 64cc combustion chambers, and 2.02 intake and 1.60 exhaust valves. These heads will be sent out to be ported.
I want a powerful street motor that can be driven on the street for fun and sometimes at the 1/4 mile. I have the block which is prepared, and have not purchased the rotating assembly yet. Plan to use the eagle kit with aluminum flat top pistons and a cast crank.
What do you guys think? Picking a cam is a very important part of engine building.
Before I plunk down the cash, it would be good to get some input from some vette guys. After all, you all know what I like!
Thanks guys. Also, when building the motor, I will post pictures.
John
I'd probably stay with a flat-tappet hydraulic given the heads - otherwise, any overhaul should be a roller if you can afford it
Given the port size, I'd leave some lift on the table for driveability - CompCams XE274H? The heads max out flow at about .500 lift. I did a quick DesktopDyno Advanced run with this setup (using 10:1 CR) and found 380HP@5000 and 438TQ@3500. Going to the next cam up (XE284H) netted 384HP@5500 and 426TQ@4000 - clearly not worth it with these heads.Should be an interesting discussion
FYI, I always recommend filling out the forms for CompCams, Crane, etc. and getting their recommendations directly. As you note - it's a key decision and ultimately one you have to make.
you can check out the videos in my signature also if you want to here the cam to get an idea where you stand as far as lift/sound/idle goes....one is when we first cranked it with rusted out exhaust and the other is during a little joy ride with brand new exhaust on it
I'm running a 383 with Dart heads, 200 cc ports, 64 cc chambers. You need a better flowing head. The small port will really limit what the engine is truly capable of. My setup is very steetable and still breathes at higher rpms. Ditch those heads!
Problem = $
To get any good flow numbers out of them is going to cost near the price of a new set of Sportsman II or Brodix iron heads
Me too
I used 6" rods.
As for John's cam:
Those heads won't support a whole lot of cam. However, flattops & iron 64cc 383 resulting compression would indicate a need for more cam in order to bleed off some compression. Looks like a mismatch seeking a place to roost.
Suggest a dished piston w/ iron 64cc 383 combo ... and a moderate cam.
Octane requirements are directly proportional to compression ratio ... pump gas ain't so great these days; I expect it to only get crappier.
I build dedicated circletrack motors for 110 race gas ... and a few street motors. ie ... currently assembling a vortec head (iron 64cc) 383 for a pal's dailydriver pu truck. About 9.2:1 scr & 197*/207* .460"/.480" cam ... hyper piston is SpeedPro H890CP w/ -23cc dish with felpro 1094 steel 0.015" shim head gasket. G'Luck!
The extra cubes aren't really buying anything with those heads. Always tough when you have good parts (and you do) but they don't quite match up to the intended use :/
http://store.summitracing.com/partde...5&autoview=sku
This is a little overwhelming!!
Oh and BTW, if these heads will do, what cam will work with these? I imagine that a higher lift and more duration might work.
Thanks guys.
John
