1980 exhaust question
Old Aug 3, 2007 | 12:03 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Default 1980 exhaust question
I have a 1980 style exhaust on my 82, I’m using the driver’s 2” ram horn manifolds on both sides since I’m not using any smog or heat riser valves.
The drivers side bolts up pretty tight to the flange with the 2” doughnut gasket, but I noticed the flange on the passenger side is a little larger and allows the doughnut gasket to sink in a little more.
My question is: I’m assuming the ram horn manifold that is normally used with a heat riser valve is flat on the bottom.
But on the bottom of the valve that has the rounded section to mate with the exhaust flange……is it a little larger than a 2” gasket?
I’m wondering if I need to chop off the passenger side exhaust flange and weld up a flange just like the drivers side to make sure it seals correctly.
I hope this isn’t too confusing…….Thanks again!
Old Aug 3, 2007 | 01:12 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
I can't see any reason you would have to weld up anything new. But I'm not claiming to know everything about it either. I would think if the exhaust flange is long enough it should seat ok with the ramhorn. I have the ramhorns on mine with the heat riser valve though. I've looked at it and it looks like everything would be fine with with the donut gasket and extended flange. Just my .02 though.
Old Aug 3, 2007 | 02:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Got the '80 AIM? I'm thinking there's a spacer on the passenger side, but don't quote me on it. It's been a long time since I crawled around under there.
Old Aug 3, 2007 | 03:27 PM
1982CorvetteDude
I got an 82 AIM, using a 80 exhaust system on my car
Yeah the heat riser is the spacer your talking about I think. I wonder how thick it is?
I had my exhaust bolted up for the last six months and it seemed ok, but since I have it out right now I wanted to do a few things to make it easier and maybe last longer.
My manifolds and exhaust are designed for the 2" doughnut gasket.
Right now the flange on the passenger side looks like it would take a 2-1/2" doughnut gasket...it's that much bigger than the drivers side....I'm assuming that's because of the heat riser valve.
I was thinking about just getting another 2" drivers side flange and weld it up on the passenger side to make things more "equal"
I'll take pics tonight to show what I'm talking about.
Old Aug 3, 2007 | 03:39 PM
1982CorvetteDude
Could someone educate me as to what this "sleeve" is for? I noticed this the other day and I don't have them. Do they help seat the gasket?
Old Aug 5, 2007 | 11:06 AM
chrisd0729's Avatar
chrisd0729
Here's the exploded view....
Old Aug 5, 2007 | 12:42 PM
1982CorvetteDude
Hey Thanks,
I ended up ordering a riser spacer, two sleeves yesterday. Hopefully it'll go back together a littler better and not cause any problems with my gaskets not seating right.
This really important because I have an oxygen sensor on the driver side right below the doughnut flange and air coming in pass the gasket messes with my computer and causes it to dump more fuel in the engine.
To 1980 exhaust question
