Small Base Circle Cam?
Old Aug 4, 2007 | 10:35 AM
nastee383's Avatar
nastee383
Default Small Base Circle Cam?
I'm seriously thinking of selling my 383 shortblock and replacing it with either a 396, 421 or 434. My question is does a SBC with standard deck height require a small base circle cam with a 3.875 or 4.00" stroke crank?
Old Aug 4, 2007 | 10:39 AM
gkull's Avatar
gkull
Even more so! 3.750 to 4 inch stroke swings the rod bolts .125 closer
Old Aug 4, 2007 | 03:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
This is a significant clearance issue. Go with the small base circle and, still, verify everything w/clay before final assembly. Oh, and some shops don't clearance at both rod bolts, so be sure to install them in proper orientation.
Old Aug 4, 2007 | 05:29 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i just built a 396 sb and used the small base circle cam with eagle h beam stroker rods. i had no problems at all.
Old Aug 4, 2007 | 07:00 PM
gkull's Avatar
gkull
Is it up and running?
Old Aug 4, 2007 | 07:37 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I built a 396 with a std base circle cam & the Eagle H-beam stroker rods. The engine is running with no problems. I'll do the final break-in tomorrow & then transfer it back to the engine stand to check all the torques. Anything larger than a 3.875 stroke & I'd just automatically choose the small base circle cam. If you don't go with stroker rods then go with the small base circle.
Old Aug 4, 2007 | 08:17 PM
nastee383's Avatar
nastee383
Thanks for the info
Old Aug 4, 2007 | 09:32 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
it's ready to run, i just have not fired it off yet. i will be taking it to the dyno in the next few weeks. i will post a vid of the dyno run.
Old Aug 5, 2007 | 12:48 AM
gkull's Avatar
gkull
I have had this 4340 forged 6 inch rod 3.875 stroker crank sitting around. With a set of 415 ci rod & pistons. I'm going to do an old four bolt block 4.040 bore which makes right at 400 some ci. We are using off his 355 ci 65 Nova motors Drag car his Edl Victor Jr heads, Motown single intake, and my old SR cam I had.
I will take picture of the block pan rail clearing.
Just like anything end of the year racing and they have to do it now
To Small Base Circle Cam?
