Pings like crazy.
Old Aug 5, 2007 | 07:42 AM
R96IMP's Avatar
R96IMP
Default Pings like crazy.
Got a 79 w/a 406 and the motor pings like crazy any time I get on it.Doesn't matter if its hot -195 or cold,it still does it.Set total timing to 32 degrees w/no vac advance and it still does it 93 octane,HEI advance is all in at 2850.12 degrees at the crank initial and and 20 more as the rpm comes up.
36 degrees was worse and the vacuum adv makes it sound like baby rattles.
HELLLLLP!!!!
Old Aug 5, 2007 | 10:09 AM
GDaina's Avatar
GDaina
back off on the timing.....
Old Aug 5, 2007 | 11:22 AM
ZL1powr's Avatar
ZL1powr
HELLLLLP!!!!
Are you sure your timing marks are correct? You can find TDC with a piston stop in the #1 cyl. Might be a good thing to check.
Old Aug 5, 2007 | 02:41 PM
rcread's Avatar
rcread
Do you know what your compression ratio is? What heads are on the car?
Old Aug 5, 2007 | 07:45 PM
weimer20's Avatar
weimer20
I need to know what cam, what head, what compression in order to answer with any degree of intelligence.
Old Aug 5, 2007 | 10:18 PM
Tim H's Avatar
Tim H
Thats a shame!
Theres nothing you can do, short of losing power with every move but redo it all. Sux
Old Aug 6, 2007 | 12:23 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
CR? Cam?? Heads??? Under what conditions???? Without more info none of us can help much.
...and do verify that your balancer marks are indexed properly, as ZL1powr alluded to. Could be running a lot more advance than you realize.
Old Aug 6, 2007 | 09:34 AM
PETKAH's Avatar
PETKAH
Had the same problem in a '70 - after a proper tune up I used GM Top
Cleaner to get the carbon out - after that it ran fine.
Old Aug 6, 2007 | 02:37 PM
bob_robert's Avatar
bob_robert
Default I had the same problem
My 78 with a 406 would do the same thing. After trying different things I was able to fix mine by-
1) Running a colder set of plugs, AC R43TS
2) My HEI had an adjustable VAC Advance Can so I slowly kept adjusting it until the pinging went away.
Runs great now no more pings.
Hope this helps
Old Aug 7, 2007 | 04:27 PM
weimer20's Avatar
weimer20
Hope this helps
I had to do the same thing with my 383. Took some of the vacuum advance out and all was well.
Old Aug 7, 2007 | 09:55 PM
Mike's 68's Avatar
Mike's 68
Do as ZL1powr says and verify your timing mark! I bought a piston TDC stop (SUM-900189) from Summit for $6.95 the best money I ever spent on a tool. I had the same problems as you, I gave up on vacuum advance and had a rattle everytime I step on it (thought it was the manual chock cable hitting the air filter base - wrong). Turned out that the timing mark that my car was tuned to was wrong. The harmonic balancer had two marks about 38-40 degrees apart. What a difference, just ran 0 to 60MPH in 5.7 seconds with no rattles or pings.
Old Aug 8, 2007 | 12:13 AM
R96IMP's Avatar
R96IMP
Engine was asssembled and running before I got the car.No idea on cam,slight lope,last owner said he remembers something about 268 something,his words,not mine.That tells me a 268 degree @.050 cam.Would account for slight lope in idle....Compression NFI no idea on pistons
441 heads.No headers,just 2 1/2" with Flowmaster 40s.
Stock style intake from a later model,poss 305.Pings without vac adv hooked up as well.
Any acceleration more than slight will make it ping.
R44TS plugs at .043 gap.
Got to get TDC figured out...will try the TDC stop and get a degree tape for the balancer.Might have WRONG front cover and/or pointer.Just realised that some of the tin may be from the old L-48.
Old Aug 8, 2007 | 12:32 PM
Ironcross's Avatar
Ironcross
see if it will run better with some better fuel, {race gas}. Help to isolate the problem by possibly eliminating one or two.
Old Aug 8, 2007 | 04:25 PM
jmiller1819's Avatar
jmiller1819
3rd Gear
Default Only pings under load?
I just had a tune up done on the car, and they said they checked my timing and reset a few things and everything was great now, but on my drive home, I have a pretty steep hill I have to drive up.... everything was running and sounding great until I go to the hill, and then I started to hear some serious knocking as the engine took on the heavier load.
I'm guessing the vacuum advance is too great ... but still trying to get a handle on the whole timing thing... trying to understand all the different settings.
Am I on the right track at least? Should I just retard the timing by *2 and run up the hill again to see if the knocking goes away?
I should also mention that I had no knocking issues at all before the tune up....
Thanks!
Old Aug 19, 2007 | 08:31 PM
R96IMP's Avatar
R96IMP
Found the problem!!!!!!
Remember I said the engine was already together when i got the car????
Who ever put it together,put the timing pointer in the WRONG 2 holes on the front cover ......wonder what else????
Old Aug 19, 2007 | 09:36 PM
TheSkunkWorks
Glad it was simple. Always pays to sweat the "small" stuff.
Old Aug 20, 2007 | 06:21 AM
R96IMP's Avatar
R96IMP
Simple is a relative term.....Still have to pull the WP and fan to correct.Wish I had a clutch fan(7 blade)ready to go on.Gee guess I could upgrade to the aluminum pump.....What's better,the Edelbrock or the Stewart???
Old Aug 20, 2007 | 03:40 PM
TheSkunkWorks
Yeah, I should have said "relatively simple". At least it wasn't something fundamentally wrong with your engine's setup.
Those same two pumps you mention are at the top of my list. Dont' know if it's "better", but I'm planning to install an Edelbrock Hi-perf on my 496.
As for the fan, you could always go dual electrics.
Old Aug 20, 2007 | 04:51 PM
dmrodco's Avatar
dmrodco
A lot and more octane !
To Pings like crazy.
