No High Speed Blower Fan?
Old Aug 6, 2007 | 08:54 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default No High Speed Blower Fan?
1981 Corvette the blower motor works on all speed but high. What is the problem or where to look.
Old Aug 6, 2007 | 08:59 PM
SIXFOOTER's Avatar
SIXFOOTER
Her you go Ed
check that out, see if it helps
The Hi Blow relay is on the firewall just above the evaporator box, the contact on the bottom has a habit of burning off
Old Aug 6, 2007 | 09:00 PM
LYLE's Avatar
LYLE
Not sure on a 81 but 73's had an in line fuse near the horn relay just for the highest speed on A/C cars.
Old Aug 6, 2007 | 09:16 PM
SIXFOOTER's Avatar
SIXFOOTER
81 it feeds right off the fuse link, no fuse. Livin on the wild side
Old Aug 6, 2007 | 09:59 PM
Corvette ED
Well I was thinking that it is either the relay, resistor, or the fan switch in the console.
Old Aug 6, 2007 | 10:13 PM
SIXFOOTER's Avatar
SIXFOOTER
Resistor is out of the circuit on High. If the Hi Blo relay picks up the switch is good
Old Aug 7, 2007 | 05:01 PM
Corvette ED
The problem was a bad relay. Thanks to everyone who helped.
To No High Speed Blower Fan?
