bad starter?
Good luck c3 Melissa
This is the switch mounted to the top of the column above your ankle, not the key switch at the top of the column. I spent a lot of time and money chasing a starter issue that didn't solve the problem. It too was somewhat intermittent and I had convinced myself it was the starter.
I then spent 5 minutes testing the switch and discovered that it was not fully engaging the start position, so even though I had power to everything else, none was going to the solenoid. I removed the switch and found that it was coming apart and that was why it was not fully engaging the start position. Fixed the switch and no more problems.
Yes these things do have heat soak issues from time to time and the mini starters do a good job as well as some of the heat shields that you can attach to your starter. But if the switch is the issue, all of the money you spend on the starter will not correct the problem.
Good luck... GUSTO
Dint get talked into aftermarket parts and trick setups, the OEM stuff is the best for your enjoyment and reliability.
hey now
it LOVES the pink.Well it ran for a while but wouldn't start later on last night. My mechanic was over working on something else so he checked it out, the brand new battery was almost dead, and turns out the car has the wrong alternator and belt anyway, so we're going to replace those tonight.
Heat soak is a amatures answer to the problem and always wrong....
The stock copper-plated aluminum battery cables are also total garbage. The new Delco replacement cables are pure copper and made far better than the stock parts.
Only with the introduction of the small 4 cylinder cars did they go to the lighter imported style starters as a lighter weight saving move. in the middle 70`s. The GM starter your referring to is a permanent magnet starter That will replace both late big blocks and small blocks as similar in performance as the new Ford starters. The newer Vette starters are a breed all by themselves and if I recall correctly they are the gear reduction style.BTW, that permanent magnet GM starter is a excellent choice to replace those heavy big ones. .... :lol, ...No
I'm surprised, I read most of this and there hasn't been the old "to use a mini starter or not" debate.
Good Luck
If you don't have headers, then a stock style starter w/ a heat shield would probably be ok. Otherwise you would most likely have to go the route of a mini. Unless you enjoy a PITA install because of clearance issues. Anyway thats my 2cents based on my experience with both types. Hope it all works out for you.
