Headlights Don't go Up
Old Aug 8, 2007 | 08:41 PM
76yellow's Avatar
76yellow
Default Headlights Don't go Up
I just bought a 1980 vette with some issues. The one I'm starting with is, the headlights don't come up. I got them to come up once by pulling the overide but now that does'nt do anything either. I put a vacuum gauge at the T at the headlight relays & do have vacuum there. I don't have a manual for an 80. Is the system different from my 68 & 76 vettes ? Any ideas where to start trouble shooting ?
Old Aug 9, 2007 | 01:22 AM
cooljoe57's Avatar
cooljoe57
Sounds like either a vaulty acuator seal or acuator. I'm having the same problem with my passenger side (just havnt got around to replacing the seal).
-Joe
Old Aug 9, 2007 | 06:23 AM
crazywelder's Avatar
crazywelder
Originally Posted by cooljoe57
Sounds like either a faulty acuator seal.
If you have a hand vacuum pump, you can diagnose the actuators by connecting a hose to the vacuum port on the bottom of the headlight actuator (the bottom port opens the headlamps, the top port closes the headlamp) and see if you can pump each headlamp open manually. If you can't open them with vacuum, the actuator shaft seal is probably worn out and leaking. The seal costs about $10 at the Vette parts distributors. A lot cheaper than buying new actuators. Just be carefull disassembling the retainer that holds the seal in place, the tabs that are bent over are fragile. Good luck.
Old Aug 9, 2007 | 07:54 AM
...Roger...'s Avatar
...Roger...
Vacuum at the small white hose T tells the lights to stay "down"
Remove vacuum at the T and this tells the lights to come "up"--providing you have vacuum at the yellow striped center hose on the relay.
To Headlights Don't go Up
