A.C. Problem 1970 vette
Old Aug 9, 2007 | 09:51 PM
squirrelguy's Avatar
squirrelguy
Default A.C. Problem 1970 vette
Hey gang. After replacing all of the WORKING parts of the A.C. system, compresser, expansion valve, receiver drier and all hoses, and having the P.O.A. valve re-built by classic air. The system WILL NOT accept a charge. Something seems to be blocking the low pressure side and not allowing freon to be drawn in. High side evacuates fine. Low side evacuates so quickly, that most likely only the hose it self is evacuating, not the low side of system. Any Ideas before I just sell the whole car out of exteme frustration. Can't find a shop in my area the specializes in these older systems and trouble shoot it for me. My guess is the P.O.A. re- build. They were the weakest and most problematic part in these systems as I remember anyway. HELP.
Old Aug 9, 2007 | 10:45 PM
MikeMc71's Avatar
MikeMc71
It would be nice to know where here actually is..........I have a guy I go to here in Tucson, he has 3 '71 Chevys (not vets), but he knows his A/C.
Old Aug 10, 2007 | 04:07 AM
squirrelguy
"Here" is Shrewsbury Pa.
Old Aug 10, 2007 | 07:37 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I had a similar problem a while back and it ended up being a bad gauge hose. Try switching the high pressure hose with the low pressure hose on the gauge set and see if you can charge the system. Also, I'd replace the schrader valves on the car. You might also hook up your vacuum pump to the high side only and after you've pulled a good vacuum, push in the schrader valve on the low side and see if your vacuum is lost. This should tell you if there is something blocked in the system. It sounds like something simple to me. Good luck.
Old Aug 10, 2007 | 07:43 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
did you replace the drier? and if yes, did you install it quickly as not to let humidity accumelates inside?
Also, old POA valves are very easily cloged by debris, did you replace that with a new original or upgraded one?
Old Aug 10, 2007 | 08:51 AM
71 Green 454's Avatar
71 Green 454
I also just had the same problem and it turned out to be a defective schrader valve on the low (suction) side. Also, years ago I had a similar problem and it was a defective POA valve.
Old Aug 10, 2007 | 08:46 PM
squirrelguy
Thanks, I will try that. Someone else also told me about possible shrader valve problem. Didn't give it much creedence because the hose assembly is brand new. Will address them though. Can't hurt. Thanks again.
Old Aug 10, 2007 | 08:49 PM
squirrelguy
Yes, replaced drier and quickly covered and sealed the ends for a couple of weeks until I was able to assemble the rest of the parts for the system.
Old Aug 10, 2007 | 08:50 PM
squirrelguy
Had the original POA valve rebuilt .
Old Aug 10, 2007 | 10:05 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I think moisture will contaminate the drier even if you seal the ends for the period of two weeks. you need to either fill with freon gas or vacuum all the air out. I always leave the drier sealed inside the house till the last moment of installation then I rush to the nearest a/c shop for vacuum and fil.
again I am not 100% but someone will correct me if I am wrong.
Old Aug 11, 2007 | 11:21 PM
squirrelguy
I'm sure your right, but will that not allow a drop of freon to enter the system. tried for an hour to fill through the low pressure side, and it just wouldn't take a drop. Pretty sure now it's a bad rebuild job of the P.O.A. valve. Disconnected it and tried to force air throught it, and it would not go. Something inside of it has it completley blocked. sending it back hoping they will just give me a refund and then I will buy the updated P.O.A. valve that converts it to an electricaly cycled system. Those original P.O.A. valves were ALWAYS a problem anyway!!!! Just a weakest part of the system.
Old Aug 12, 2007 | 01:31 AM
71 Green 454
Here's a link to a site that covers adjustments made to POA Valves in older systems.
http://www.autoacforum.com/messagevi...&threadid=7567
Old Aug 12, 2007 | 01:46 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
You are right, in my humble openion, the old POA valve should never be used even if its a new NOS. Its always a better idea to use the updated electrical cycles ones. I know someone will be upset about not keeping it original, but I am talking about DD vettes here.
Old Aug 12, 2007 | 08:18 AM
squirrelguy
Thanks for the link VERY Interesting and helpfull
To A.C. Problem 1970 vette
