Towing hook?
Old Aug 10, 2007 | 03:43 PM
agent kronus's Avatar
agent kronus
Default Towing hook?
has the 78 vette got a towing hook on the front of it?
cheers
Old Aug 10, 2007 | 03:44 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I don't believe you'll find one that the General put on as original equipment.
Old Aug 10, 2007 | 07:14 PM
agent kronus
cheers
Old Aug 10, 2007 | 07:28 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
No towing hooks that I know of. I use "T hooks" that I bought at Northern Tool when trailering my 71 between Florida and Ohio. In the front there are oval shaped holes right behind the sway bar mounts and in the rear there are similiar holes on the cross member that is in front of the rear tires. I assume that the 78 frame would be similiar but perhaps someone else can verify that assumption. Some forum members have stated that these holes are used during transport from the factory. I don't know but it would make sense to me. You do not want to attach to your suspension if you can avoid it. One thing I did have to do was install additional tiedowns in my trailer to keep the front tiedown straps from rubbing against the front airdam. The front factory tiedowns were installed too far forward in the trailer.
http://www.northerntool.com/webapp/w...70_43572_43572
Old Aug 11, 2007 | 10:44 PM
VettePower's Avatar
VettePower
cheers
We are talking abouit Vettes, and not 4-wheelers aren't we?? Get serious, dude!!
Old Aug 12, 2007 | 02:01 AM
cboyd's Avatar
cboyd
cheers
No hooks that I know of. The frame has some cut out areas, probally for shipping or access.
Old Aug 12, 2007 | 12:23 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If any car hauler / tow truck driver doesn't know how to properly hook up your C3 with the slots mentioned previously, decline his services and call someone else if they won't listen to you.
Do not hook up to the suspension, front or rear.
Old Aug 12, 2007 | 12:45 PM
JoeC427's Avatar
JoeC427
Old Apr 23, 2015 | 02:02 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
We made front and rear tow hooks for the C7 corvette. See here. Www.zl1addons.com
Old Apr 23, 2015 | 09:16 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Cars with factory tow hooks had to ride a Boat to get to America.
Old Apr 24, 2015 | 01:06 AM
Doug Kraft's Avatar
Doug Kraft
I hope like hell you never have to be pulled anywhere to get it off the road or to a safe place while you wait for a wrecker(rollback). I have one on mine and won't take it off for nothing or nobody.
Old Apr 24, 2015 | 08:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...has the 78 vette got a towing hook on the front of it?...
Have you found one?
Old Apr 24, 2015 | 09:00 AM
Street Rat's Avatar
Street Rat
Bubba must have installed a towing hook on mine 'cause there is one there. I've had to use it a time or two and it works great.
To Towing hook?
