Electrical problems, headlights and turn signals dont work
We recently also did a minor rebuild on the steering column and replaced the signal assembly, at first only the right turn signal worked prefectly okay, the left signal would just make rapid clicking sounds and the parking light would flash, so i though it mightve been a faulty bulb in the rear, after replacing it (it was pretty messed up) both turn signals just made rapid clicking noises and didnt work.
The front wiring harness is brand new, with all the bulbs put in and hooked up correctly, the rear license plate light is out though could this cause a break in the circuit or something?
I have little experience with working with electrics on this car, since most of what I have been doing has dealt with suspension, brakes, and engines, so any help is appreciated.
Also, is the wire that hooks up to the thermostat supposed to be green?
Thanks in advance
Just noticed that when I press on the brake the left turn signal indicator inside the car remains lit.
I would get a test light and check for voltage in the car at the firewall connector. You said you changed the front harness but make sure the connections at the firewall are clean. This should get you parking lights and headlights.
This could be the firewall connection or something is not right in the steering column
Trace for power at parking light switch I think it is a brown wire 16 gauge and work yuor way back to the licence light make sure socket is good
