I'm trying to replace the seat belt retractors in my '79. There are two trim pieces (one per side) that fit directly between the T-tops and the rear window. They curve down and cover the interior of the B pillars as well.
Mine will not come off (at least not easily). I have removed the four upper screws on each side, the lower screw near the door on each side, and the coat hook on the passenger side. I see no other mounting hardware.
All the screws are visible there on that piece. If I remember correctly, there are 5 screws. I think one does attach through to the small 4" piece "L" shape, that attaches to the big trim piece that goes the whole wat around the back.
