1977 TH350 not upshifting.
Old Aug 12, 2007 | 09:34 PM
Durango_Boy's Avatar
Durango_Boy
Default 1977 TH350 not upshifting.
Interesting drive this afternoon. Got the interior almost all finished, minus a shift boot that doesn't fit the shifter plate and an overheating problem...
...I found that the transmission did not upshift out of first.
I checked fluid. Clean, red, smells great, and at filled level when warm.
I verified the detent cable was in place on the throttle linkage on the carb and that it seemed to be adjusted properly.
Could the pump be going out and it doesn't have enough pressure to shift? It shifts from park to reverse and neutral just fine, same as going into drive. It stay is first gear.
Any ideas?
Old Aug 12, 2007 | 09:39 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Check the vaccume line to the shift modulator (?).
Old Aug 12, 2007 | 09:43 PM
Durango_Boy
Good call I did not check that. I'll do that tomorrow. Thanks.
Any other ideas?
Old Aug 12, 2007 | 10:13 PM
markdtn's Avatar
markdtn
First place to start. And if you are losing fluid but not leaking the modulator is also a first place to look.
Old Aug 12, 2007 | 11:12 PM
Durango_Boy
I'm dumb with transmissions. How do I check the modulator?
Old Aug 12, 2007 | 11:28 PM
682XLR8's Avatar
682XLR8
Matt, check the governer also. It's located on the pass side, under a stamped sheet metal cap held in place with a piece of stiff wire, similar to a brake master cylinder. Check that the governer isn't frozen up, and everything moves freely.
Centrifical force causes the weights on the governer to move outwards, pushing in on the valve, and enabling the shift from 1st to 2nd. Hope this helps out
Old Aug 13, 2007 | 12:05 AM
Artsvette73's Avatar
Artsvette73
Put vaccuum to the modulator valve it should hold a vac.
Old Aug 13, 2007 | 12:15 AM
billla's Avatar
billla
St. Jude Donor '14
I ran into this regularly on my '72 C10 until I finally just put a hose clamp on the line
Old Aug 13, 2007 | 12:20 AM
billla's Avatar
billla
St. Jude Donor '14
There is a hard line that goes from the back of the modulator - it's on the passenger side of the rear of the TH350...looks kinda like a fuel filter - to a fitting on the intake manifold. Most likely it's just worked loose and you just need to slide it back on.
Old Aug 13, 2007 | 07:14 AM
Durango_Boy
I'm familiar with the line. I'll crawl under there this afternoon when I get home to check.
Thanks for all the help guys.
Old Aug 13, 2007 | 07:44 AM
markdtn's Avatar
markdtn
Old Aug 13, 2007 | 07:49 AM
...Roger...'s Avatar
...Roger...
Matt you dont have to crawl under -just put a vacuum on the line going to the trans from the manifold.You did put that line back on didnt you?
Crawl under???? You dont have a lift yet??
Old Aug 13, 2007 | 07:54 AM
Durango_Boy
Well I need to get under the car because I never disconnected the line at the top that goes to the manifold. It's dedicated...meaning it's the only vacuum draw from that port at the back of the manifold. I know the line is solid there and must now check the bottom.
I wish I had a lift but I do not have the height in my garage for one and I can't afford a steel building yet.
Old Aug 13, 2007 | 08:00 AM
...Roger...
Get that concrete saw out and build a pit.
Old Aug 13, 2007 | 08:37 AM
SIXFOOTER's Avatar
SIXFOOTER
My 77 had a TH400 in it, you sure you got a 350?
Old Aug 13, 2007 | 08:40 AM
Durango_Boy
According to the pan, it's a TH350.
One of the other two '77s I had did have a TH400, but this one is for sure a 350.
Old Aug 13, 2007 | 09:14 AM
ghoastrider1's Avatar
ghoastrider1
good luck on that issue DB. Hope its something quick,easy and cheap.
To 1977 TH350 not upshifting.
Old Aug 13, 2007 | 09:22 AM
Durango_Boy
I had another thought. I did not attach the vacuum lines for the headlights to the headlight switch. I am going to mount a stand alone switch for the actuation of the headlights so I can control them independently of the light switch. Similar to the stock switch but with more control.
Anyway, I did not complete that task and left the tubes dangling under the dash. I totally did not even think about the resulting vacuum leak.
Since that part of the vacuum system comes off of the carb and the transmission line comes from the port on the manifold...
...would the loss of vacuum in the cab like that cause there to be so little vacuum that the transmission would not upshift?
I know it shifts into reverse just fine, and I always thought that it takes more pressure to shift into reverse than any of the forward gears.
So, knowing it shifts into reverse just fine and that I have a huge vacuum leak...can I rule out or pinpoint anything?
Old Aug 13, 2007 | 09:29 AM
MN81C3's Avatar
MN81C3
Last month I had the same thing happen. When they installed my headers and pipes, they accedentally knocked off the Vac line to the trans. I was able to shift it manually from 1st to 2nd to get to a tranny shop. Good Luck DB.
Old Aug 13, 2007 | 09:31 AM
Durango_Boy
Interesting. Mine will not upshift manually. I did not think they were even capable of doing that except within the normal standards of it wanting to like in drive gear where it will decide.
I know that you can start in first, and shift manually into second but that's because the transmission already wants to and you're not manually changing the gears.
It'll shift up as high as you let it but the shifter doesn't seem to move it to second before it's ready to shift anyway.
