Starter issues / Solenoid?
Old Aug 13, 2007 | 07:41 PM
Pat 1977's Avatar
Pat 1977
Default Starter issues / Solenoid?
I have a 77 vette that starts right up when cool but does not start after running, parking, and trying to start up again. Typicaly happens when engine is still hot and starts up in a few hours once cool. Battery is fine. Connections are fine. When trying to start there are no sounds at all, no clicking etc. Is this a starer solenoid problem?
Old Aug 13, 2007 | 07:54 PM
...Roger...'s Avatar
...Roger...
Replace the solenoid
Old Aug 13, 2007 | 09:44 PM
yel76low's Avatar
yel76low
Yup. Cheap fixes are great, aren't they.
Old Aug 14, 2007 | 10:08 PM
Pat 1977's Avatar
Pat 1977
I've never worked on a car before and found replacing the solenoid to be no issue. Car didnt start at first but later did. Got fed up and brought it to a local classic car guy who said I need a starter. I'm going to have him put it in while I'm gone this week. Should be finished by the time I return. Thanks for your input.
Old Aug 14, 2007 | 10:19 PM
birdsmith's Avatar
birdsmith
I may be too late here, but my '70 was exhibiting the same issues last year but a little less severe- starter would drag badly when hot. It's the original starter, so before taking my chances with a rebuilt starter I replaced the battery with a new one from Wal-Mart. Say what you may about Wal-Mart, their batteries absolutely KICK BUTT! The car sits for three and four weeks at a time between drives especially during our 100 degree-plus summers but that sucker just cranks like a beast now, hot or cold.
Old Aug 14, 2007 | 10:56 PM
Busrydr's Avatar
Busrydr
Are cars are notorious for this issue. Quick fix is the solenoid. But if the solenoid failure is due to heat, you can add an insulation cover around the started for reduce the heat getting to the system.
Many times with headers, that does not last. Other solutions are to make sure you have a good quality starter and solenoid.
And if all of that still fails, there are 2 certain fixes:
1. Relocate a the solenoid away from the starter - Kits sold in some of the major parts stored like Summit
2. Get a mini starter - smaller but more efficient and can take a lot more heat with less draw requirement
Old Aug 14, 2007 | 11:19 PM
Z-man's Avatar
Z-man
A remote starter solenoid is only about $19 bucks and is a permanent solution to starter heat soak (unless you are looking for a NCRS restoration.)
Old Aug 15, 2007 | 08:10 AM
pws69's Avatar
pws69
This is the longest standing "old wives tale" in Chevydom!!!
You cannot relocate the solenoid in a Chevy V8!!! You can ADD one - but all a "remote" solenoid does is add another switch in the line. You are STILL using the solenoid on the starter the exact same way. And is does NOT "cure" the problemm
You should either replace the solenoid or switch to a "mini" starter as previously suggested.
To Starter issues / Solenoid?
