68 ride height!
Old Aug 13, 2007 | 08:45 PM
racecardrvr4's Avatar
racecardrvr4
Default 68 ride height!
i just finished the frame on my 68 and i dropped the body back on but it looks like the car is sitting to high. can anyone tell me what the ride height is from the ground to the frame (measuring from the ground to the bottom of frame, just below the door) please, can someone measure theirs, i would appreciate it. this is driving me crazy!! mine is measuring around 11 inches.
Old Aug 13, 2007 | 08:53 PM
...Roger...'s Avatar
...Roger...
About 7"
Old Aug 13, 2007 | 08:58 PM
dbeall1968's Avatar
dbeall1968
Is it just the front? Do you have your engine in? Mine sat really high until I dropped the motor/trans in. Then it settled.. The assenbly manual has all the measurements, if you don't have one and need these, just pm me and tommorrow I'll scan the page and send it to you. Got any pics?
Old Aug 13, 2007 | 09:10 PM
tlynam's Avatar
tlynam
Is there gas in the tank? Is the interior in? The extra weight may help settle it down a little. Also, I assume that you rolled it around a little after putting the weight on the rear suspention to let the spring spread out.
Old Aug 14, 2007 | 02:02 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You're looking for the Z, D, K and J trim heights, which can be found in the AIM or CSM for your year.
I'm attempting to gather all of this data for every year and model C3, but don't have 1968 yet, or I would certainly share.
If anyone has that complete info, please post up at either of the following threads after you tell racecardrvr4 what they are. Many thanks.
http://forums.corvetteforum.com/show....php?t=1783961
http://forums.corvetteforum.com/show....php?t=1785016
Old Aug 14, 2007 | 10:12 AM
MELVIN's Avatar
MELVIN
1. The early C3's sat high. We get so used to seeing cars with old springs, we get used to seeing them sit lower. Many folks change out the front and rear shocks over the years, but many do not change the rear springs, or front springs
While I dont have the 68 exact ride height w/me right now, look at this 68 original sales add:
http://www.corvette-world.com/corvet...der-p-169.html
Looks high back then, doesn it?
Ill send pics of my restored one, with new springs all the way around nextand
Old Aug 14, 2007 | 10:28 AM
MELVIN's Avatar
MELVIN
http://s140.photobucket.com/albums/r6/WFFW/
Here is my 68. New shocks and springs all around
Old Aug 14, 2007 | 12:45 PM
TheSkunkWorks
If anyone's interested in Power Book road race prep heights...
Z @ 1" - 1 1/4", D @ 1 1/4", with driver & fuel. This is considerably lower than most C3's ever came from the factory.
Here's the '78 specs, for instance...
Should have the '68's by the end of the day, hopefully.
Old Aug 14, 2007 | 01:14 PM
...Roger...
J and K what are their definitions? Cant be from ground to frame.Must be from bottom of molding to ground.
Old Aug 14, 2007 | 01:41 PM
TheSkunkWorks
J and K are measured "from the under side of the sill molding (appearance line) to the ground."
I generally don't pay attention to those, however, as I'm more concerned about suspension geometry for my purposes, but they're certainly easier to check.
Old Aug 14, 2007 | 02:03 PM
...Roger...
OK thats makes sense. Those are called "trim heights" specs. I believe.I think he was looking for "frame to ground" clearance dimensions.I have them for a 63 for some reason but thats all.
He said he is 11" from frame to ground---WATCH YOUR STEP signs are needed.
Old Aug 23, 2007 | 02:36 AM
TheSkunkWorks
Sorry to have promised those specs based on a promise to me that never came to fruition.
To 68 ride height!
