Pertronix II or POINTS ?
Old Aug 15, 2007 | 08:30 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Pertronix II or POINTS ?
My OM 72 base Coupe had a Pertronix Ignitor II when I bought it 4 years ago. It is still installed. In the last 4 years, I have had my carb (beautifully) rebuilt by Lars.....I have set up my distributor and timing as discussed here on the forum. It always runs "OK" ...... BUT it NEVER runs the same. Sometimes it starts right up when cold....others times it takes 3 or 4 starts to even idle right. Same when hot. It's a "crap shoot". Sometimes when hot, it just shuts off sitting a a stop light. Never idles at the same rpm. I have set and re-set the timing 20 times.
I am thinking about putting in a good set of Napa Points / Condensor just to see if that may be the variable.
Any ideas or opinions ????
Old Aug 15, 2007 | 09:12 PM
C3 Stroker's Avatar
C3 Stroker
Points are like going back to hand cranks to start the car....antiquated. However, there may still be a problem under the dist. cap, but I would check the carb float level and go from there...
Old Aug 15, 2007 | 11:45 PM
72LS1Vette's Avatar
72LS1Vette
Sounds more like a carb problem than a distributor problem, unless your distributor is in need of a rebuild. If the Pertronix uses the original coil that could also be an issue. The problem with points is that they work fine when new but deteriorate gradually as they wear, but I suspect you would have the same type of erratic performance if you put in points and condenser. Electronic ignitions tend to either work or die.
You might also want to check for other things like vacuum leaks. Vettes have plenty of places for vacuum leaks to occur.
Edit: If Lars rebuilt your carb you can probably eliminate that as the source of the problem. I would focus on a worn distributor, vacuum leak, cracked hose, etc. If your master cylinder has been leaking any brake fluid in to the booster the seal may be shot and you could have a vacuum leak there.
Rick B.
Old Aug 16, 2007 | 02:11 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
M&H Fabricators Point eliminator kit + a stock coil from them = trouble free ignition system
Old Aug 16, 2007 | 03:42 AM
hwcoop's Avatar
hwcoop
Also make sure the Pertronix was installed correctly to begin with, you should have between .010 to .060 end play, you can adjust end play with shims.
The electronic ignition shouldn't vary like that, what shap is your timing chain/ motor (high mileage?), fuel system, pressure/filters etc
Old Aug 16, 2007 | 07:59 AM
desi's Avatar
desi
Did you have these problems before touching the carb?
Old Aug 16, 2007 | 08:32 AM
pws69's Avatar
pws69
Just a thought....when you start the car, you ARE waiting 15-30 seconds AFTER you turn the ignition on before you actually START the car, right? My Pertronix has been rock solid going on 3 years, but if I rush it, it will start hard. Wait 15-30 seconds and it starts right up every time.
Mine has never had a stalling problem, however.
Old Aug 16, 2007 | 08:44 AM
BarryK's Avatar
BarryK
I'm not a fan of the electronic conversion kits for distributors. They gain you nothing at all except the expense of the kit with zero performance gain for your money spent.
Personally, I would remove the pertronix and send the distributor out to Lars to have him rebuild it back to correct specs and put it back to a points system. A points distributor that is within correct specs and tolerances with a good set of high tension points runs great.
I change out my points and condensor once a year on my '65 every Spring when I get the car ready for the "season". It cost about $12-15 and takes 15 minutes or so to swap them out and reset dwell and timing - not a big deal. Thats 12 or 13 years worth of fresh points for the cost of the pertronix kit with overall greater reliability.
If the goal is to increase performance than upgrade to something like a factory GM HEI tach drive distributor rather than use a conversion kit such as the pertronix - that will at least gain you hotter spark.
I'll agree with the previous poster that said that if your carb was rebuilt by Lars than chances are it's not a carb issue. looking for a vacuum leak would be a good idea to start with than have the distributor rebuilt so you know it's correct and working as well as the carb is.
Old Aug 16, 2007 | 09:59 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
[QUOTE=BarryK;1561520746]I'm not a fan of the electronic conversion kits for distributors. They gain you nothing at all except the expense of the kit with zero performance gain for your money spent.
QUOTE]
Or a good ignition box + points.
I use a vintage aluminum Accel dual point, tach drive, ball bearing dist. running one set of points with a Crane HI-6 box.
The points act only as a switch so they will never burn and probably out last the Pertronix .
The only missfire I ever enconter is bouncing off the rev limiter....which is another benefit of an ignition box
Old Aug 16, 2007 | 11:08 AM
427-390's Avatar
427-390
Not only that, if you have a failure with one of the pointless kits that are available, you're kind of sunk. You can easily carry a set of points and condensor and replace them on the fly if they should ever fail. Never understood why so many bash the conventional points type ignitions.
Old Aug 16, 2007 | 01:29 PM
Solid LT1's Avatar
Solid LT1
Open your points adjustment window in the dist cap, run a ground wire from the points mounting plate to the engine block and see if there is an improvement of the performance. Many time I find a car with a bad running Igniitor to have a grounding problem. I always remov the distributor and tear it down completely whan installing a Ignitor unit. There is a grounding wire from the bottom of the points plate to the distributor housing, this wire is often broken or ready to fail. The centrifigal advance and vacuum advance units should be tested and properly lubrcated. Your tach drive gear should be checked for play and properly lubricated. Many people throw in these conversions and expect miricles when there are other existing problems. When a Ignitor unit is put into a properly rebuilt distibutor, the difference is noticiable with instant starts, and improved bottm end power along with smoother operation.
Old Aug 16, 2007 | 01:32 PM
C3 Stroker's Avatar
C3 Stroker
Quick comment....why do you wait 15-30 seconds before starting? I ran Pertronix for over 10 years (Pert. I, and later upgrading to Pert II), and NEVER had a start problem or a need to delay. Always immediate starts.....what gives???
Old Aug 16, 2007 | 07:49 PM
pws69's Avatar
pws69
Perhaps I have a different version that behaves differently? Right out of the book. I seem to remember "lobe sensor".... That long, huh...
Old Aug 16, 2007 | 08:22 PM
ajrothm's Avatar
ajrothm
I would just put points back in it. GM used them for 30 yrs and cars have run hundreds of thousands of miles with them. I have had the same set of points in my car since 1988 and about 45k miles and I have never even gone back and adjusted them or cleaned anything... My car runs perfect hot or cold and even has a junk Auto Zone q-junk on it.
Go to Napa, get some points....be done with it.
Old Aug 17, 2007 | 02:58 AM
Richard454's Avatar
Richard454
I've been running the Petronix II for several years... I've never had to adjust it- clean it- or replace it (unlike points). The car idles smoother and immediately starts every time -even after sitting a month or two.
HOWEVER- it might be due to the fact I used synthetic grease in the distributor and cleaned it w/ synthetic brake fluid!!!!
Old Aug 17, 2007 | 10:13 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I use this Breakerless SE system on mine, but I got it through Lectric Limited.
I know that points, when set up properly, provide great performance. The only reason I went with the breakerless system was for convenience. I hated fiddling with points.
Does my car run better? Well, I also shimmed end play and cleaned up the weights, changed the springs, lubricated everything, etc., so, yeah, my 'vette does run better. So I know that it isn't from the breakerless system alone: A clean and tight distributor is better than a dirty and loose one.
Again, my change from points to breakerless was for convenience. It's been over three years since I installed it without any problems, so I'm happy with my decision. Your opinion (like mileage) may vary.
Old Aug 17, 2007 | 11:54 AM
billla's Avatar
billla
St. Jude Donor '14
I've been running a Pertronix Ignitor II in a 350 HP 355 SBC for about 2 years with absolutely no isuses at all. It's a daily driver that sees > 5000 RPM once a week or so '-)
I agree with the comment regarding taking the time to set it up right - I did have to shim my distributor shaft, which as noted should have been done anyway. Completely agree that regardless of the system it needs to be set up right in all particulars.
To Pertronix II or POINTS ?
