Directional lights
Old Aug 18, 2007 | 11:21 AM
Lilfur's Avatar
Lilfur
Default Directional lights
I just lost my directionals both left and right. I have flashers. I checked fuse on both sides and have 12 volts. Changed flasher relay. I have horn. Any other idea's ?? Do the diect. have a seperate ground ??
Old Aug 18, 2007 | 05:57 PM
Durango_Boy's Avatar
Durango_Boy
Did you change the signal flasher or just check the hazard flasher? There are two flasher relays. The signal flasher is on the passenger side clipped up under the knee pad. Just get on your back on the floor and you'll see it clipped just under that knee pad.
If you have checked and or replaced that flasher then I would suspect a bad bulb or a bad ground.
