electrical glitch
Old Aug 18, 2007 | 08:24 PM
early71's Avatar
early71
Default electrical glitch
Hope I can get some answers here,I have lost ALL electric power on 4 separate occassions.Nothing,not the horn,lights etc.Here's the wierd part,it lasts for only short time,once for less than a minute..it then lights up and runs fine.Ihave tightened battery cables,checked frame to ground connections at engine and rear as well as starter connections.Also checked bulkhead fuse connection,today while going to a show,alternator shows discharge so we came home.I'm only showing 12.4 at battery and alt.connection.Hope you gurus have some answers.....jc
Old Aug 18, 2007 | 08:29 PM
tjhuyser's Avatar
tjhuyser
wild guess...could be a collapsed plate in the battery...when that happens the battery will be like a dead short sucking all the juice...I have a problem in my wifes honda...everthing will be fine.. I park the car and 5 minutes later try to restart and the battery is dead..have to jump start..then it's fine again for 2 monthes..the alternator should be putting out 13.5 or so with out any electrical devices on and the engine running
