Hey DB. I have seen this happen before. It may,or may not, be the case here. At idle and slow RPM,the charge was fine or marginal. Upper RPM.voltage drop. In this case, the fault was in belt slippage.
Serpentine slipping at 2000+? Hmm...interesting aspect but I hear no slipping and it seems to me it's unlikely. Thanks.
if your engine is grounded ,thus your alternator case is as well.
Not necessarily, there is paint, grease, dirt whatever on the bracketry and I have seen s bunch of these things NOT have a cood gase ground. A good, heavy copper wire ground directly on the case to the frame is better
If you have a CS130 in your car it will work the same way my CS144 works. I bought a cs alternator plug and pigtails, the red wire coming from the pigtail gets soldered to the red wire in the factory wiring (this is for remote sensing which will maintain 14 volts at power junction, not the back of the alternator) the black wire in the plug does not get used, and the brown wire in the plug has to have a 330 ohm resistor soldered in and then connect that to a switched ignition power source. (THis is what excites the alternator and switches it on) Then hook your ground up and the red wire to the bat on the back of the alternator. Test the voltage with the car off at the batt terminal, then start the car and test it again, should read 14+ volts(this is ok because it will have a slightly higher voltage at the back of the alternator just to maintain the 14 volts at your power junction) Then rev the motor while watching the voltmeter, shouldn't fluctuate but a few points of a volt. If your factory voltmeter matches what your multimeter is saying a light isn't nessecary in my opinion... I can post pics of my install later tonight if you want
Also check out this site, lots of important info on wiring CS series alternators...towards the bottom it mentions CS130 alternators and the various models they have and how each have to be wired differently. http://www.offroaders.com/tech/Alternator-Theory.htm
You only need the resistor if you don't have a "GEN" light.
WORK ??? When did you get a job??? I thought you were a KEPT man.
Ha ha...my buddy and I started a business and we try to keep our own set hours. I have the freedom to make my own schedule but I won't make money if I always leave when I want to.
Matt-just looked at the pic of your setup.Slipping is possible-you dont have alot of belt contact.Make sure you cant turn the alt. pulley by trying to rotate the fan with your fingers.If you cant turn it that should be OK.If you can turn it by hand it will slip.
Yeah I checked that when I installed it, and it won't turn by hand. I can check again tomorrow too.
Good Plan-stick to your set hours.You cant make money working on cars while on a computer or working on your own stuff.
(Guess what-Im working on a dang ol Dodge-puttin a supercharger on a hemi magnum)
I used a multimeter this morning when the car was off and cold and checked both the battery and alternator BAT terminal to ground.
The alt, and the case is grounded just fine, had 12.90V and the battery had 13.09V.
I started the car and the alt had 14.54V and the battery had 14.30V. This all seems fine at idle.
I could not get it to duplicate the previous symptoms and the GEN light never lit and the voltage would not drop when I goosed the throttle. I let the engine warm up, so the alt was hot, and all readings stayed the same and I could not get the GEN light to even flicker.
Sucks because I can't diagnose the problems if they hide from me.
Right now I still have the hot 350 I built for it a decade ago.
You built an engine when you were 6 years old?
I would suspect a bad connection. Measure the voltage at the battery and repeat the test.
edit: i see you already did that. A bad connection is gonna come and go. Try again later. The voltage at the alt is going up because the load is disconnected intermittantly. The voltage reg backs down because it thinks its overboosting.
The only difference is I have added a 4 gauge jumper wire that goes from the alternator's BAT terminal to a distribution block that also has a 4 gauge wire running down to the starter BAT terminal.
I was going to run a third 4 gauge wire to the battery, and a fourth for the second alternator when the 405 goes in.
I double checked all the connections and they are all solid and tight. I checked for broken wires and corrosion in the stock wires and found them to be in fine shape and I can't see any arcing to the valve cover from any of the hot wires on the alt.
