Suspension upgrade worth it?
Ok, I have seen allot of upgrade parts out there and my question is has anyone tried them, do they work? Worth the money?
By upgrades I mean as far as all out mono spring front with mig A-arms and mono glass rear spring ect... (the works)
Or leave the front springs as coil over and just do the back?
I have to go through all the bushings anyway and the prices are not that bad for new aftermarket parts, like I noticed where my rear sway bar mounts to the trailering arms its starting to tear the metal!
I do not want to apply 500hp to this suspension and have it fall apart being that its from 69. I do not plan to race the car it will be a show car and weekend cruiser but I still want to do it right and not cut corners.
Any responses on good or bad options and things to stay away from and things that are a good way to go let me know.
Any responses on good or bad options and things to stay away from and things that are a good way to go let me know..........
For example my show condition boat has a 1200hp blown 540 in it and goes way over 100mph on the water
I want a suspension that will take the abuse when that time comes
Save your time and money. If you're not using it for autocrossing or track racing, the stock suspension is more than good enough.
As far as a stock restoration thats not going to happen as the original 427 was gone along with the 4 speed and rear end, also the whole interior was changed out and all but a few parts of the ac setup are gone too
So I figure make the car what I want it to be since you will never have a TRUE numbers matching car and I am not in the market of restamping parts and trying to pass them off as original.
I plan to keep the car true to the 69 look without flaring or adding anything to the body except the hooker side exhaust and torq thrust II rims.
I will probably build a 427 out of a Dart competion block with aluminum heads and a electric fan cooled radiator setup. I have a 71 muncie and picked up the correct rearend for a BB car
Just looking at the time and money points of repairing and fixing all the old suspension that has seen some abuse over the years and just taking it off and boxing it up and putting on new and improved parts
Ok so far I like the mono rear spring, have heard 3 people that have tried it and love it.
I see Ecklers sells some stronger trailering arms, since mine are rusted and starting to tear that looks like the way to go huh?
Replace the tie rods, ball joints, front springs, sway bars, and shocks and I should be good to go. The guy I bought it from allready put on new calipers and rotors and replaced a few of the lines.
And replace all the U joints in the half shafts and drive shaft.
Everyone think that original driveshaft will hold up to 500hp?
When i opened the box the first thing that came to mind was
Art Work!Go Van Steel !!
If you are concerned about breaking stuff and you aren't drag racing, the biggest thing you need to do is stay away from heavy flywheels. 3" half-shafts with solid Spicer U's have proven to be pretty durable if you don't get them in a bind by running too low. As for the differential, it's not cheap, but a 12-bolt IRS diff is far stronger than the 10-bolt design. I think every C3 should have a solid diff. cross-member locating kit installed. It's not a bad idea to blueprint your stub axle bearing clearances, and you might ought to consider changing to 1/2" lugs while you're at it (I like Guldstrand's HD stubs).
Another thing to do is toss the eccentrics and install a set of adjustable heim-jointed (not to be confused with poly bushed types) camber struts with camber lock plates. And, if you need tire clearance, the double offset TA's may be a requirement. BTW, you can get a shortened spring, too.
Finally, be careful not to get caught up drag strip mods (particularly, eleminating camber gain) that compromise suspension geometry for most other types of driving. Thus, I wouldn't bother with DragVette's 6-link for your purposes. There are several things you can do in the rear suspension to improve handling, but that's the topic for another thread.
http://forums.corvetteforum.com/show....php?t=1735609
another forum member http://s65.photobucket.com/albums/h2...sc=6&start=all
What differences did you notice from stock to the new suspension?
Would you do it again?
The last link I see he got his stuff from VBP, is yours also from there?
Thanx!
much better ride, those bumps n potholes on michigan roads don't hurt as much as they used to
NO, i don't have to since i already did it
So I have 2 vette rear ends one small block and one BB
This 12 bolt IRS ?? What is that and where do they sell it?
Thanks again for the help.
PS got the body all loose tonight and ready for lift off onto the temporay frame
First one was done by a local shop that's long gone. 4.11:1 with Moroso posi. Proved too deep a gear for my purposes, and the posi tended to ratched violently coming out of sweepers when trying to put down power.
Second one ws done by Henry's Machine works. 3.55:1 with Eaton posi. If I ever sell my SA, it stays with me.
Currently, Tom's diff seems to have this market in hand. They've got a lot of hardcore C3 rearend stuff. Here's a link to the diff...
http://www.tomsdifferentials.com/catalog.asp?pg=22
BTW, you do NOT want to completely eleminate camber gain for anything other than drag racing.
