More power window problems. Could use some help.
Old Aug 20, 2007 | 03:23 PM
#77's Avatar
#77
Default More power window problems. Could use some help.
When I bought the 'vette both power windows were not working. Replaced both missing motors and both switches. (Both switches were bad). Windows worked fine. Went to drive it this weekend and both windows will not work. I am thnking that it may be the relay. I have power to one terminal at relay harnass when key is on so i think problem is after that. Is there a way to test relay?
Thanks for any advice.
Old Aug 20, 2007 | 07:21 PM
njcardave's Avatar
njcardave
Default power window problem
I had the same problem with my 75. I replaced the relay and all is well.The relay for my 75 is under the center console, good luck.
