tranmission fluid leak
Old Aug 20, 2007 | 04:41 PM
corvette8189's Avatar
corvette8189
Default tranmission fluid leak
i brought my 81 to a tranmission shop to see what it was and he said it some seal on the front of the trans and it would have to be removed to fix and he quoted me 325$ to do it. is this reasonable or should i go somewhere else or do it myself thanks
Old Aug 20, 2007 | 05:03 PM
S489's Avatar
S489
with cost of living increase, that sounds about right. the only gotcha might be if the torque converter is damaged at the seal. otherwise, if you do this, have all of the gaskets and o-rings replaced including both the front seal and gasket
Old Aug 20, 2007 | 08:41 PM
ghoastrider1's Avatar
ghoastrider1
once you get to it, its an easy fix. Just a PIA job.
Old Aug 20, 2007 | 11:36 PM
Z-man's Avatar
Z-man
Sounds reasonable...
Old Aug 21, 2007 | 10:36 AM
Stewart's74's Avatar
Stewart's74
PIA job is an understatement. I'd pay someone else to do it in the future...
Old Aug 21, 2007 | 12:48 PM
corvette8189
im not doing it i brought it to a tranmission shop and there gonna do it for 325
Old Aug 21, 2007 | 04:44 PM
corvette8189
dang i got bad news its the the freaking torque converter
Old Aug 21, 2007 | 04:48 PM
Pete K's Avatar
Pete K
To do the job properly, I would suggest replacing the front pump bushing as well.
Old Aug 21, 2007 | 09:40 PM
corvette8189
ya the dude is gonna replace the bushings and seald and torques converter and gasket and all orings and stuff for 550 good deal i think what do yall think
Old Aug 21, 2007 | 10:04 PM
Pete K's Avatar
Pete K
Sounds fair enough.
To tranmission fluid leak
