compressor cycling to much
Old Aug 21, 2007 | 08:19 PM
Tom68's Avatar
Tom68
Default compressor cycling to much
OK, Got the AC charged cooling great but compressor is cycling evry 15 seconds with the instalation of the POA eliminator kit. Any ideas?
Old Aug 21, 2007 | 08:45 PM
7T1vette's Avatar
7T1vette
I think that is normal for a modern system. Original C3 systems ran all the time when "on"; modern systems "cycle" and are much more efficient.
Old Aug 21, 2007 | 10:22 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
system should not cycle that much, but its hard to toruble shoot without more info.
clutch is controlled by suction side pressure switch, system pressure is very dependent on ambient temp (outside and inside of cabin).
could also have a high side shut off switch, was it converted to 134a or is it still r12?
at 30 psi suction the coil temp will be below freezing and condensate will freeze on coil, this is also dependent on cabin temp and air flow. the suction pressure switch is there to try and prevent this by cycling the comp off when pressure gets low enough.
If the system is under charged or low on freon it will also cause the comp to cycle on and off.
Neal
To compressor cycling to much
