Idle and drive gear problems.
I guess I should add that this all started with a backfire through the carb. Before this start, where it backfired, it idled and ran fine.
I can adjust the idle mixture screws but it will either get faster or slow and start shaking badly.
The choke was already hot so I can't test it, it's electric.
When I put it in a drive gear like drive or reverse the rpms drop to about 500 and it shakes really bad like it's going to die and I hear a sucking noise like the carb is sucking in air through a straw.
I checked to make sure all the spark plug boots were in place and secure and that the cap was latched down properly.
I have tried rotating the distributor a little each way or back to the middle where it seems to run the best.
I'm confused so who has some ideas?
I guess when it backfired it popped that cap off and it was sucking air in.
I didn't know a vacuum leak could cause it to run so crappy.
