Stingray Hood Scoop
Old Aug 21, 2007 | 07:24 PM
tristan69's Avatar
tristan69
Default Stingray Hood Scoop
Has anyone installed this hood scoop on a stock chrome bumper 350 hood?
It is from Speedway Motors. Here is the link http://www.speedwaymotors.com/p/6170...itemNo=9001375
I figure it would give it a cool stinger look.
I have some small cracks in the hood and need to paint it anyways.
I might even cut a hole for a bigger manifold.
Old Aug 21, 2007 | 07:44 PM
dewcustom's Avatar
dewcustom
Old Aug 21, 2007 | 07:45 PM
dewcustom's Avatar
dewcustom
I think it looks better than buying a "stinger" hood it gives you a much wider "V"
Old Aug 21, 2007 | 10:06 PM
tristan69's Avatar
tristan69
Originally Posted by dewcustom
Nice, did you cut a hole for the air cleaner?
Old Aug 21, 2007 | 10:40 PM
cal camara's Avatar
cal camara
How did you attach it.
CAL
Old Aug 22, 2007 | 12:19 AM
miechesa's Avatar
miechesa
Fiberglass it in.
Old Aug 22, 2007 | 01:39 AM
panic's Avatar
panic
...stingray scoop on an eckler's high rise hood...
Old Aug 23, 2007 | 03:46 PM
tristan69's Avatar
tristan69
I just ordered my hood scoop!!!
Can't wait.
Did you cut a hole for the air cleaner, and if so how much bigger did you cut it?
Old Aug 23, 2007 | 03:58 PM
7T1vette's Avatar
7T1vette
That is really a nice looking hood. Adding that scoop to a SB hood, some glasswork and paint provide a "killer" look. That's almost as nice looking as the 67 stinger hood.
Old Aug 23, 2007 | 04:03 PM
Greg's Avatar
Greg
Just another Corvette guy
One of those scoops was installed on my '70 when I bought it. I removed it when I had the car painted. :lol:
Old Aug 23, 2007 | 04:22 PM
tristan69's Avatar
tristan69
Why did you take it off?
I guess yours was just cosmetic.
I need hight for my new engine and will cut a hole in the hood, so I like this option.
Old Aug 23, 2007 | 04:33 PM
Greg's Avatar
Greg
Yes, mine was just cosmetic and I thought it cut up the clean lines of my small block hood.
If you need the height for engine clearance it might be the best way to go.
Greg
Old Aug 23, 2007 | 07:09 PM
7T1vette's Avatar
7T1vette
I don't think it messed up the lines of the hood...I think it wreaks of testosterone!
Old Aug 23, 2007 | 10:39 PM
olouieo's Avatar
olouieo
Old Aug 24, 2007 | 04:41 AM
Greg's Avatar
Greg
HEY!
Your comparison pics aren't fair.....
You're showing a '69 with an incorrect hood from a later year.
Old Aug 24, 2007 | 08:05 AM
dewcustom's Avatar
dewcustom
Can't wait.
I cut out everything under the scoop and smoothed it into the hood so it all looks like one peice
Old Aug 24, 2007 | 08:10 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
While I'm not one for customizing Vettes, your hood looks great!
To Stingray Hood Scoop
Old Sep 29, 2007 | 04:33 AM
tristan69's Avatar
tristan69
I just placed the scoop on my hood and I do not have the inch or so on each side of the stinger point as you do (gap between the outside edge of the stock point and the inside of the new scoop).
Did you modify the scoop or bend it out when you installed it?
Also, it looks like you cut off the back hang over to be flush with the hood line, am I correct in this assumption?
Do you know if your scoop was the same company?
http://www.speedwaymotors.com/pl/424...ood-Scoop.html
Old Sep 29, 2007 | 08:43 AM
dewcustom's Avatar
dewcustom
it sounds like you may want to get a wider scoop and i left the hang over in the rear.
Old Sep 29, 2007 | 11:41 AM
carriljc's Avatar
carriljc
Default my 68 had one of those....
when I bought it. I replaced the hood with and L-88 hood. The old hood was cracking at the corners.....I still have the old hood; I oughta toss it.
