L48 Head Question
I was thinking about having them machined and larger valves installed. MAybe polishing the ports.
If this can be done, what size valves should I upgarde to. (intake & exhaust)? The only other modifcation that I would be doing right away would be a slightly larger cam and true dual exhaust.
Add to it a Summit cam and lifter combo, an Edelbrock Vortec manifold, and have your carb tuned or rebuilt.
Follow that with a complete tun up, plugs, wires, fluids, filters...blah blah.
When you can afford it after all of that, have some headers and true duals installed.
That'll get you some pep.
Then if you're still looking to spend more, drop some coin on an overdrive transmission of some kind and rear gears better suited for the engine and transmission combo.
ID love to se that write up... My 77 L48 runs strong but in the morning its blowing smoke so i think its a valve issue. So heads and a cam down the line seem to be in the picture.
I was a kid and was on a cheap cheap budget. A little each week
Good Luck
You could have these ported including a bowl and chamber sweep, have 2.02/1.6 valves installed and upgrade the springs...but you'd still be well short of the power in virtually any aftermarket cast iron head and have more money (figure $1K+ by the time all is done) in them. And, you'd have mucked about with your original heads.
There are aftermarket heads that you could paint orange that have accessory holes and are perimeter bolt for the stock valve covers. You'd need to stay under .450 lift or so with the stock valve covers. I've used 1" spacers to get the stock valve covers up high enough to cover roller tip rockers...but it's pretty visible.
IMHO, you'd get more "grunt" from a mild cam upgrade than investing in new heads - and it's less impact on your original engine. I *think* the stock cam is .390/.410 lift; investing in something like the CompCams 12-205-2 or the 12-230-2 would provide a nice SOTP increase in low-end torque with a bit of sacrifice on the top end. The additional lift wouldn't buy all that much, but the duration would help a bit. You'd need to very carefully check the valvetrain geometry for coil bind, etc.
I did some mucking about with Desktop Dyno Advanced including modeling the 3663152 cam and saw 40+ TQ (flywheel) gain through about 4500 RPM with the 12-230-2 cam. I also tried the stock cam with a set of Dart Iron Eagle heads and picked up about 6HP and 8TQ. Note that DD is NOT definitive by any means - and it all depends on the quality of the models - but it's pretty decent at these type of comparisons for engines making < about 1.4 HP/CID.
Power is all about matching components - improving the heads doesn't buy much without a corresponding cam upgrade...and it goes on from there
IMHO it wouldn't be easy to push past about 300 HP (flywheel) if you're sticking with the stock manifolds.
tyler77@kc.rr.com,
NHRalph@aol.com,
Dltalfa@aol.com,
stewarth@samsungsoa.com,
brio71@comcast.net,
bud2@dodo.com.au,
glassbowtie77@netscape.net,
badman@free.net.nz,
jgrigg0903@yahoo.com,
bizdata@ix.netcom.com,
ptroxx@sbcglobal.net
Please let me know if you don't get it or if I missed anyone.
http://www.corvettefaq.com/c3/goodwr...20part%201.htm
hope it works for you.
Heads were the only place I scrimped on my engine when I built for my 76. Details in my profile...she's got 6" aluminum H-Beam rods, all forged lower end and yada yada yada ...
But I did not buy myself aluminum heads
I got the 4-bolt main block and a boatload of goodies, but the end result: I missed my horsepower goal and have an engine prone to ping when the weather is hot.
It runs great and I am quite satisfied but I know it would have come out better if I had not spent all the money I did, on OE heads and bought aluminum ones instead. I did the porting, polishing, and even had the heads and intake port-matched.
I wound up with 275HP at the wheels. Only average as far as I'm concerned especially when I know I built the bottom end like a tank. I know I can always put better heads on it ... but that's spending good money after bad.
So I know from first-hand experience: Don't waste a lot of money on stock, cast heads. Spend the money on aluminum ones and don't regret where those dollars were spent - because the cost is the same.
