trans wont shift
Old Aug 22, 2007 | 07:20 AM
toehead79's Avatar
toehead79
5th Gear
Default trans wont shift
have 79 changed from auto to 4 speed new linkage and clutch.Trans wont go in gear with clutch in gears rip. Is there a difference in the clutch fork ball between gm models? if so do I have to take trans out or some other fix?
Old Aug 22, 2007 | 08:18 AM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like the clutch is not releasing. What did you put in there?
Old Aug 22, 2007 | 10:29 AM
toehead79's Avatar
toehead79
5th Gear
mumice m 20 the bell housing is out of 68 camaro. pedals linkage and fork new vette stuff the only thing I didnt change was shift fork stud
Old Aug 22, 2007 | 03:29 PM
Lee H's Avatar
Lee H
Did you pull the side cover and check out the guts?
Old Aug 23, 2007 | 07:25 AM
toehead79's Avatar
toehead79
5th Gear
no. but you can start the car in gear hold the clutch in ,the car start moving like the clutch is engaged, then you pull shifter into netural and it stops moving like it should.
To trans wont shift
