Caliper Dragging
Old Aug 22, 2007 | 06:17 PM
XLAR8R's Avatar
XLAR8R
Default Caliper Dragging
just got my car running again recently after after dragging my feet doing the top end and some other things and my passenger front brake is dragging after sitting for several months. the caliper has very little miles on it. i took it off and you can manully push the pistons in and out but when i put it back on theres still too much pressure and it drags and if you hit the barkes at all you BETTER be hanging on real tight cause it pulls hard to the right. any suggestions how to free it up ? thanks.
Old Aug 23, 2007 | 09:13 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Change the front flex lines. Sounds like you have a bad front left flex line but your better off replaceing both at the same time and they are cheap enough.
Old Aug 23, 2007 | 11:38 AM
Z-man's Avatar
Z-man
It won't hurt to check/replace the front flex lines. If they are original style calipers, they are SUPPOSED to drag on the rotor. The internal spring will hold the pads on the rotor. The caliper that is NOT working is the one on your driver's side - that's why it's pulling to the right. I'd get it fixed first.
Old Aug 23, 2007 | 11:51 AM
Van Steel's Avatar
Van Steel
and the caliper most likely isn't working b/c the line is collasped. Since he stated it pulls hard to the right it's almost a dead give-a-way that it's the line. Unless his caliper is leaking, which he did not mention,
Old Aug 23, 2007 | 01:02 PM
XLAR8R's Avatar
XLAR8R
neither one is leaking. it shouldnt be dragging so much that it dosent hardly want to turn right ? everything was working fine until i parked it for a few months. thanks for the tips. maybe try the lines, tks
Old Aug 27, 2007 | 11:21 AM
Z-man's Avatar
Z-man
Let us know what it turns out to be...
To Caliper Dragging
