G-Tech image
Old Nov 7, 2001 | 12:58 AM
MIKER's Avatar
MIKER
Default G-Tech image
I was playing around with a .gif animator and put together these pics from my G-Tech.
Like 'em or not, I think the G-Tech is going to be a useful tool to see if I am making improvements. (it beats guessing!) Today UPS delivered my new timing light so I hope to get my "Lars recurve kit" installed within a few days. Hopefully I will be able to create an updated image of my G-Tech showing better 0-60 times!
edit = (changed image source)
[Modified by MIKER, 8:29 PM 11/11/2001]
[Modified by MIKER, 10:51 AM 11/23/2001]
Old Nov 7, 2001 | 01:34 AM
Stoge's Avatar
Stoge
Default Re: G-Tech image (MIKER)
:cool:
Old Nov 7, 2001 | 01:46 AM
MARKUS_P's Avatar
MARKUS_P
0 to 60 in 4.9 sec ...
And you´re still not satisfied :eek:
If the G-tech reading is correct, you´ve a fast,... :rolleyes: a very fast corvette, indeed
Old Nov 7, 2001 | 10:25 AM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: G-Tech image (MARKUS_P)
heh heh, better than I can do with my 2002 (run-flats).
Old Nov 7, 2001 | 10:33 AM
gkull's Avatar
gkull
How do you like your rear 3.08 gearing? I just ask because I had 3.55 when I first put in my 700R4.
[Modified by gkull, 10:11 AM 11/7/2001]
Old Nov 7, 2001 | 11:54 AM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
man...I'd love to have that 0-60...I really wonder what mine is...
Old Nov 7, 2001 | 12:51 PM
MIKER's Avatar
MIKER
Default Re: G-Tech image (Chris Fowler '80)
MARKUS_P
If the G-tech reading is correct, you´ve a fast,... a very fast corvette, indeed
Still not satisfied??? Is there such a thing? Thanks for the compliment! Seems like I read that the new ('97-'02) Corvettes run ~4.5 sec 0-60s. I just want to run with them. I won't be able to out brake or out handle them but would at least like to keep up with them in the straights.
I even read a post in the Z06 forum where a guy had pulled a 3.85 sec 0-60.:eek: I know I can't touch that with my current setup, not even if I were to install 3.73 gears.
Is my G-Tech "correct"? I can't say for sure but it seems to be consistent. I can pull 4.95 to 5.05 sec 0-60s pretty much every time I try. The consistency alone should help me see improvements or losses.
Rhys
What times have you run with your '02? No traction?
gkull
How do you like your rear 3.08 gearing? I just ask because I had 3.55 when I first put in my 700R4. Do you have a lockup TC?
I REALLY want 3.73s but the 3.08s aren't quite as bad as I had thought they would be. 3.73s would really change the personality of the car. Right now it is wicked on the top end. It will go from 70 to 140mph+ in short order but I'm not interested in top speed, I want to be quick from 0-100 MPH.
I don't live near a drag strip. The closest one is an 1/8th mile track (Kennedale, TX). I bet my times would stink with the 3.08s. I would like to have it run from mid to high 12s to no worse than low to mid 13s in the 1/4 mile. I'll try to get a G-Tech 1/4 run after I get the timing setup done. I'm still running the old Q-jet just as it came off of the worn out L-48. I will work on the carb after I get the timing set.
Yes, I have a lock-up torque converter. It receives its lockup signal from line pressure. No electric stuff involved. It unlocks itself when moderate pressure is applied to the throttle. (3rd and 4th)
Still not satisfied with my shift points or shift firmness though. A computer controlled 480LE would be COOL. You can dial in exactly where you want the shift points. Big $$$ though.
My setup is all pretty much budget stuff. $1000 for pre-assembled 383 short block and $850 for the Trick Flow heads. All in all, I have spent $5000 on it since July. That includes engine swap, 700R4 conversion, front suspension rebuild (poly) new tires and all the other misc stuff that goes with this type of project. I have the best of nothing but so far it's working.
I want my car to be a reliable daily driver that runs strong. Good 0-60 and 1/4 mile times are just icing on the cake. I'm just trying to find a decent balance between utility and sport.
Chris Fowler '80
Man, did you see the new G-Tech that someone posted a thread about? It looks cool. Buy one and tell us about it! I can tell you that it is FUN to play with!
Old Nov 7, 2001 | 01:30 PM
gkull's Avatar
gkull
For $48 I bought a second govenor for my 700 from Art Carr. Not that hard to swap out. So I have a racing mode 6800 rpm shift in auto or my daily driver which shifts at @5000 rpm.
The next time that you have you pan off to change the filter it's also worth investing in a 1/2 inch line lockup seleniod. Because you want instant lockup to save the TC clutch
To G-Tech image
