no center bezel lights
Old Aug 24, 2007 | 10:13 PM
dabrogger's Avatar
dabrogger
Default no center bezel lights
i have a 1977 l-48. the speedo and tach lights work, however, none of the center bezel lights (i.e. temp, gas, voltage) work. also, i'm not sure if it's supposed to, but the shift selector light on the console doesn't work either. any solutions? thanks. dabrogger@hotmail.com
Old Aug 24, 2007 | 10:28 PM
...Roger...'s Avatar
...Roger...
Probably the connector on the back of the cluster.The contacts are fairly fragile.
Old Aug 24, 2007 | 11:12 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I agree. I have a 77 and i was just in mine.. Easy to take out. Dont forget the 2 screws at the bottom.
Old Aug 24, 2007 | 11:31 PM
dabrogger's Avatar
dabrogger
ive never messed with mine. could you give me a little guidance?
Old Aug 25, 2007 | 01:18 AM
7T1vette's Avatar
7T1vette
It's probably a grounding problem. Without disassembling anything, get a piece of wire (about 2-3 feet long). Strip the insulation from the ends. Turn on parking lights. Touch one end of wire to a known good ground area (or where a black wire terminates). Touch the other end to any chrome metal area on the gage cluster. Did your lights and gages start working? If so, rig up a permanent ground line to the gage bezel...the one it had no longer works.
To no center bezel lights
