Running rich!....Bogs down at WOT!
Old Aug 24, 2007 | 10:27 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Running rich!....Bogs down at WOT!
Here's the facts:
* New GM Performance crate engine....350/300 hp
* Relatively new Holley 670 Street Avenger: (1) Float position correct (2) Fuel/Air mixture adusted to highest vacuum (3) Power valve OK (4) Accerlator pump adjusted to specs.
* Brand new Holley 135gph mechanical fuel pump (9 psi on the gauge)
* New plugs...after running 20-30 miles... Black with soot (indicates running rich...but no black smoke coming out of exhaust)
* Timing: initial 9*(800rpm) 2500rpm=36*
* Bogs down at WOT from a stand still and idicates running rich
WHAT IS GOING ON!!!???????
My mechanic is going to reduce the jet sizes in the carb...will that work? He, at first, installed larger jets...situation got worse...so logic tells us to go smaller...is that correct? How about the fuel pump...to large? HELP!!!!
Old Aug 25, 2007 | 12:07 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'd go back to the stock "Avenger" jets (why the switch?). I'd also reduce the reg to 5-6 psi,..9 is too much and could be overpowering the needle and seat.
Do that and see how she runs.
If she still bogs at WOT I'd try different VS springs (stiffer).
Good luck!
Old Aug 25, 2007 | 09:30 AM
Matt Gruber's Avatar
Matt Gruber
most times a car idles fine and has black plugs it is weak ignition
but with a "self employed" guy, who knows?
Old Aug 25, 2007 | 09:40 AM
dannyman's Avatar
dannyman
Check out " Jetting the transfer ports" by, NorvalWilhelm. Just posted yesterday in C3 tech/perf.
He says testing with an LM-1 shows that we are all running to rich. Good thread by a knowledgeable member.
Old Aug 25, 2007 | 09:58 AM
Jims79's Avatar
Jims79
Do you have another carb you can try.........
Old Aug 25, 2007 | 10:13 AM
vetteguy75's Avatar
vetteguy75
Do ya'll think the fuel pump is too much? (9 psi) I read the Holley Tech Support online and it stated that a Street Avenger 670 should have between 5-7psi and anything over 8 psi needs a regulator.... Thoughts, comments, opinions??
Old Aug 25, 2007 | 10:25 AM
Matt Gruber
it will flood and stall if it can't take the pressure.
rev it to 1500, look down the the throat. is it flooding? black smoke? then stalls at idle?
cut back to 4 psi.
Old Aug 25, 2007 | 01:50 PM
Tim H's Avatar
Tim H
Its a start!!!!
Old Aug 25, 2007 | 03:19 PM
lars's Avatar
lars
I've never seen a Street Avenger that ran rich - they all run very lean out of the box, causing a very "flat" top-end. Every SA carb I've worked on needed about 3 jet sizes richer on the primaries, and significant enrichment on the secondary side to run right. Are you really sure you're actually seeing a rich condition...?
Old Aug 25, 2007 | 03:35 PM
vetteguy75's Avatar
vetteguy75
I agree! Whenever I put in new plugs and run it about 30 miles, I pull the plugs and they are black with soot.... I don't see any black smoke coming from the tail pipes.
I honest believe the fuel pump is WAY to big (pushing 9 lbs of fuel) I talked to a "gearhead" friend of mine who races Mustangs (sorry) and his 600hp, single Holley 750 runs at 7 lbs (always has and always will). He was STUNNED that I had so much pressure (with no regulator) going to the carb. He believes enough gas was pushing past the float's needle/seat that it was running rich enough to bog down and run crappy! So on Monday, I will go to the GM dealer and have them switch the monster 135gph Holley mechnical fuel pump with the smaller Holley 85gph fuel pump.
Old Aug 25, 2007 | 06:41 PM
Ironcross's Avatar
Ironcross
Have the dealer put a stock pump on it and the issue will probably go away. ....
Old Aug 25, 2007 | 07:22 PM
BigBlockk's Avatar
BigBlockk
You can very easily get a fuel pump that will put out 85 GPH and the same 9 PSI of pressure. There is a difference between pressure and flow.
Why don't you just go th NAPA and get a reman Delco fuel pump for your car? The pressure will probably be real close to 5 to 6 PSI with this crappy old nothing fuel pump that has absolutely no BLING factor at all.
Why did you put this pump on your car in the first place? Do you even know how much horse power 135 GPH represents? What made you think your car needed this much fuel?
Oh well.
BigBlockk
Later.....
Old Aug 25, 2007 | 08:00 PM
vetteguy75's Avatar
vetteguy75
My wife keeps asking me that very same question...."Why did you (fill in the blank), when it calls for (fill in the blank)" You think I would have learned my leason from past experiences!!! I thought it would have been a better pump.....
Old Aug 26, 2007 | 10:17 AM
MILO's Avatar
MILO
All the 135 GPH fuel pumps that I thought about buying required a regulator. So if you don't have one installed and you want to keep the 135 GPH fuelie, install a regulator. On Holley's, and I've played with a few since i was 18, if there is a speck of rust in the inlet needle it flooded the carb. I really good guess would be that the fuel pump pressure is over powering the inlet needle pressure.
Good Luck.
To Running rich!....Bogs down at WOT!
