Steering column reassembly problems
Old Aug 25, 2007 | 01:02 PM
ace_cobra's Avatar
ace_cobra
Default Steering column reassembly problems
i have a 70 vette, T/T and when rebuilding the upper part of the steering column i noticed that the telescopic lever sticks out about 3/4 inch from the steering wheel. It doesnt look right and it wasnt like that before so im beginning to get frustrated. I dont know whats causing it? Any help?
Old Aug 25, 2007 | 01:40 PM
Jim Shea's Avatar
Jim Shea
Are you talking about the circular telescope locking lever #7 with the finger tab that you need to rotate CCW to unlock your telescoping column? This steering wheel and horn parts scan may assist in describing your problem.
The telescope locking lever is trapped between the steering wheel spokes and the upper horn contact #3. So it really can't be off by 3/4 inch. Its position is controlled by the height of the "star" screw #6.
Use the above scan to assist us in solving your problem.
Jim
Old Aug 25, 2007 | 01:42 PM
ace_cobra's Avatar
ace_cobra
yeah the star screw wont go in far enough to make the lever flush with the steering wheel. Im not sure why though. It tightens until the wheel locks but thats it
Old Aug 25, 2007 | 01:47 PM
mrvette's Avatar
mrvette
ehh...that woodruff looking sorta key thing at bottom of the 1/4 inch shaft is outta place....me thinks that happened to me once....so even though it seems to lock, it's not really, but the screw/shaft is way the hell up in the air.....been a while....check it first place to look....
Old Aug 26, 2007 | 01:34 AM
ace_cobra's Avatar
ace_cobra
ok thanks to everyone who helped, the steering column is SUCCESSFULLY rebuilt. You were all a big help
To Steering column reassembly problems
