73 gas door
Old Aug 26, 2007 | 11:26 PM
troythefixer's Avatar
troythefixer
Default 73 gas door
I've been looking in catalogs and ebay and cannot find the gas door. I can find the gas cap all day but he gas door seem sto be eluding me. anyone havae any advice on where to find one , mine is pitted badly. I live in Tx. but the car came from Pennsylvania. Tks Troy
Old Aug 26, 2007 | 11:36 PM
Bob Onit's Avatar
Bob Onit
Pitted?
Hmmm... I thought they were made of fiberglass.
Heres the door for the '73
CALL FIRST! Docs prices are not always up to date.
http://docrebuild.com/dr-r-web/GAS-DOOR.pdf
Old Aug 26, 2007 | 11:43 PM
Green73's Avatar
Green73
Gas door is indeed metal. Haven't gone looking for one though.
Old Aug 27, 2007 | 12:02 PM
chuck d's Avatar
chuck d
The door is made from die cast I believe. You should be able to get a good used one from a corvette salvage yard. Luckily the 73 fuel door is used on quite a few year cars. I know I have seen quite a few at flea markets used.
Old Aug 27, 2007 | 12:05 PM
Bob Onit's Avatar
Bob Onit
According to Doc Rebuild -'71 to '77
Old Aug 27, 2007 | 12:51 PM
weimer20's Avatar
weimer20
I found mine on e-bay.
Old Aug 27, 2007 | 01:47 PM
Green73's Avatar
Green73
Well, a 74 lid wouldn't have holes for a emblem. I'm not sure if all the emblem holes have the same spacing.
Old Aug 27, 2007 | 02:47 PM
PatsLs1vette's Avatar
PatsLs1vette
I have one with a new emblem on it that i just took off to add my lemans cap assembly on.
Old Aug 27, 2007 | 04:48 PM
7T1vette's Avatar
7T1vette
Unless the pot metal gas door is just totally eaten up, you should be able to put it into corrosion cleaner (like CLR) to get rid of the "crud". Then use sandpaper, dremel, steel wool, etc. to clean it up and smooth the surfaces. Use body putty or JBWeld epoxy to fill pitted areas, then sand smooth again. Prime and paint....shouldn't be a problem. Since they can be repaired to look like new, no one sells replacements. Salvage yards or eBay are your only other choices.
Old Aug 27, 2007 | 05:39 PM
troythefixer
Default gas door
if you decide to sell the one you took off let me know. Troy
Old Aug 27, 2007 | 05:40 PM
troythefixer
Default gas door
Tks I'll try that and maybe have it plated after. Tks Troy
Old Aug 27, 2007 | 08:28 PM
7T1vette's Avatar
7T1vette
I'm not sure why you would want a gas door plated...unless you are thinking of chroming it. If you did want a chrome one, your best bet is to send a cleaned--but unrepaired--door. The chromer will have his/her way of fixing the pits and anything you might do to it could compromise their process. The plater will fill in the damage and get it ready, copper plate it, then chrome it. Not sure why you'd want to go to all that throuble for a gas door; you'd be better off to buy a flip-type chrome racing gas lid. They, at least, look cool. No need to plate pot metal if you are just going to paint it.
Old Aug 27, 2007 | 10:12 PM
PatsLs1vette
MAke me an offer(cheap),idlike to see it get used then sit, ill take some pics of it tommorrow morning ,pm me your email addy and ill send them.Its just gone to collect dust,ill never put it back on.
Old Aug 28, 2007 | 07:16 PM
troythefixer
Default gas door
tks I'd like to see it. troythefixer@yahoo.com
Old Aug 28, 2007 | 08:51 PM
PatsLs1vette
trying to find it i put it somewhere last week in the garage and couldnt find it before work ill check again.
Old Aug 30, 2007 | 11:07 PM
troythefixer
Default gas door
This door is on my 73 L82 it came already chrome plated but is badly pitted would like to put it back original. Tks Troy
Old Aug 31, 2007 | 06:59 AM
PatsLs1vette
Im still looking,i tore the garage apart this morning,i found the chrome trim sitting on my bench but no gas lid,i dont get it i used it for a template to make a trim piece so its here i know it.Ill look again tonight,maybe i left it at work ill look today.
To 73 gas door
