carb probs.
Old Aug 27, 2007 | 11:57 PM
clintwilson's Avatar
clintwilson
Default carb probs.
My 80 run and idled fine untill I reinstalled the air pump [match # car. part found from forum member]. now has a popping sound in the exhaust when cold ,get's better when warm , but decell. is a bit rough. Can I back the pilots out a little . Thanks for any reply.
Old Aug 28, 2007 | 02:34 AM
BigBlockk's Avatar
BigBlockk
Pilots???
What, pray tell, is that?
BigBlockk
Later.....
Old Aug 28, 2007 | 12:16 PM
427-390's Avatar
427-390
Originally Posted by BigBlockk
Pilots???
What, prey tell, is that?
BigBlockk
Later.....
Old Aug 30, 2007 | 12:26 AM
clintwilson
idle mixture screw.
Old Aug 30, 2007 | 01:07 AM
BigBlockk's Avatar
BigBlockk
Yes you can try opening up on the idle mixture screws. If you need to go more than 1/2 turn from where they are now there is something else wrong. When you put the pump back on did you make sure you got all the hoses hooked up right? I believe there is a vacuum line from the control unit of the pump to the vacuum temprature switch up on the intake manifold.
BigBlockk
Later.....
To carb probs.
