Vaccum advance fast idle problem
Old Aug 30, 2007 | 12:51 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Tim H, You don't have to take our word for it, do a little reading...there are countless articles, dyno tests and the like on getting max performance of a street motor using the entire timing system.......here's just one example...
http://www.chevyhiperformance.com/howto/97438/
Old Aug 30, 2007 | 01:17 PM
big_G's Avatar
big_G
Originally Posted by SpyderD
Ah the ported vs. manifold debate.
1st of all to the original poster, sounds like you got the vacuum advance hooked up right and your car is acting as expected with the vacuum advance disconnected. If you want to lower idle RPM (sounds like that is your concern) simply lower the idle speed at the carb.
I have mine hooked up to a ported source myself - the reason being my timing is set at the proper and desired starting advance already (16) and, with my idle vacuum with the cam I have, my timing and RPM would bounce around like a ping pong ball as it would never be all "in". So ported works for me.
I would have to get a new vacuum can that brings in all the advance at a lower vacuum for manifold to work, not sure if there would be any benifits. But I agree vacuum advance is benificial for a street driven car. Also, and I am not sure if it's a material issue at all, I never liked the tought of advance diving down (as a result of vacuum decreasing) for that moment as you enter WOT from idle.
The fact that the vacuum advance goes away quickly at full throttle is a good thing, as the cruise total advance (above 36 and below 52) would be too much (damaging) for the engine to handle. That is another reason to use a quick mechanical advance curve and as much initial as your engine can stand, to fill the timing void (caused by the loss of vacuum advance at full throttle)....
Old Aug 30, 2007 | 02:04 PM
norvalwilhelm's Avatar
norvalwilhelm
Why at cruise is above 36 and below 52 too much? I run 52 degrees total at cruise and motor seems quit happy and my mileage along with carb modifications is up at least 50%
This 52 degrees total is a recommended amount. Check out Lars paper.
Old Aug 30, 2007 | 02:16 PM
SpyderD's Avatar
SpyderD
Yes I agree. But my point is, and again this may have such a minor effect as to be irrelevant since it is so quick, is this -
timing at idle with vc connected to manifold - 20 (as an example)
then from idle you go to WOT - total timing suddenly decreases to pre-vacuum advance level (lets say 4), if but for a moment, then mechanical advance (RPM driven) timing raises it to 36 total.
timing at idle with vc connected to ported - 16
then from idle you go to WOT - total timing does not decrease at all, but increases as mechanical timing raises it to 36 total.
As you point out a quick mechanical advance curve will decrease any effect, if any, of this.
Norval - I think BigG is saying cruise timing 52 is to high for WOT, which I think we all obviously agree with.
Old Aug 30, 2007 | 02:26 PM
big_G's Avatar
big_G
Only gave a range 'cuz some engines can't take much cruise advance, though most can. I get a little bucking just at 52.
Old Aug 30, 2007 | 06:28 PM
cloue's Avatar
cloue
Also please speak in normal english if you would?[/QUOTE]
I'm a french canadian and I appreciate strongly advices on this forum. Sometimes I may have answers. But according to Tim H, if I don't write perfectly english, it's not a good idea to answer. Or to ask. It's sad for all Corvette lovers Who are speaking another native language. At least I tried to be well understood.
Just too bad !
Old Aug 30, 2007 | 06:58 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just too bad ![/QUOTE]
Cloue,
I agree. It is unfortunate at times. But, I think you'll find most of us are very patient regarding language issues. It's my guess that most of us in the forum are not bilingually fluent, so we are usually respectful of those who can communicate in multiple languages. The more prevalent problem seems to be those who are technically illiterate, and have a chip on their shoulder regarding others who may have more knowledge on a particular subject. There's a wide range of talent on this forum, and we can all learn new stuff if we keep our ears open and our egos in check. Please don't let that guy disuade you from participating in these discussions.
Mike
Old Aug 30, 2007 | 08:57 PM
Tim H's Avatar
Tim H
the thermal efficiency of the combustion dropped like a rock
Up above is what I meant in plain english, not you poor mistreated Canuks!
I can read almost anything on here, its the i dotters and t crossers that have to show their smarts when they can't find any other way to contribute!
Old Aug 30, 2007 | 09:30 PM
BarryK's Avatar
BarryK
because someone gives actual accurate technical information rather than guesses and wrong misinformed information they are than referred to as "i dotters and t crossers" and are made fun of because they actually know what they are talking about??
This IS a TECHICAL discussion forum. If the purpose isn't for techincal information than what's the point?
Old Aug 30, 2007 | 10:40 PM
...Roger...'s Avatar
...Roger...
Originally Posted by 69427
It's normal. When you disconnected the vacuum advance, the thermal efficiency of the combustion dropped like a rock. Find the idle problem, and then be sure to run with the vacuum advance canister connected.
It is normal english and very accurate as to what is actually happening.If when 69427 posts you take the time to read it you can better understand the subject.It reminds me of the old ads-when E.F.Hutton speaks everone "should" listen.When 69427 posts..."I" listen!!! I might have to read it several times for it to soak in but I guarantee you I will have learned something and have a better understanding.I believe he takes extra time putting his posts into words most can understand "if" they want to.I for one appreciate that!!!
Keep up the great posts Mike.
Oh and about the dotting every i and crossing every t...thats just being accurate..try not adjusting every valve or only torqueing half your rod bolts...
Old Aug 31, 2007 | 12:54 AM
73-L-48's Avatar
73-L-48
Cruising
I am just trying to share my experiance with the original poster. I am eternaly greatfull to the members that share their knowledge and time with me and the world and for that Street Driven Corvettes must operate in varied conditions as oposed to drag queens. By the way, Tim H my wife has a matching set of burgandy shoes and purse to match those valve covers. Get your mechcanic on here so we will all understand what you mean.
Old Aug 31, 2007 | 01:29 AM
woodlandcorvette's Avatar
woodlandcorvette
My setup liked the vac advance plugged into ported like spyder.Not to disaggree with anyone but in my case the vacuum at idle in gear was 6 due to my cam and living at 8500 ft above sea level and my idle would not stop bouncing. I could have bought a different vac can but now I have no issues with idle or any other speed so why change what works. My timing is set to 12 initial 36 at 3000 rpm and 48 total for the fast burn heads. I also had to change my power valve in my carb to 3.5 and that cured my off idle stumble. These rules on tuning can very depending on sea level, setup,and other conditions and dont work for everyone. The nice thing about my setup is I havent had to touch it for over a month now and can just drive.
Old Aug 31, 2007 | 02:48 AM
  #33
Graemeinvette's Avatar
Graemeinvette
Why am I reminded of the old story of a woman watching her son in a military parade saying "Oh look they are all out of step except our Charlie!"
G
Old Aug 31, 2007 | 05:23 AM
  #34
BarryK's Avatar
BarryK
if you have a different cam in your motor there is a good chance you need to change out your vacuum advance cannister to a different model. You want to measure your vacuum level at idle and choose a vacuum advance unit that pulls in at about 2"HG below what your measured vacuum is. So, if for example, your cam only allows your vacuum at idle to be at say 14" HG you want a vacuum advance unit that pulls all in by 12" HG.
Having said that, even Lars says that while the vast majority of cars will see an improvement by switching your vacuum source to full manifold vacuum each car is different and there are some that seem to respond better by running off the ported vacuum but these are the exception rather than the rule.
Old Aug 31, 2007 | 11:18 AM
  #35
69427's Avatar
69427
I love that analogy.
Old Aug 31, 2007 | 05:54 PM
  #36
cloue's Avatar
cloue
I understand what Tim K Meant now. Let me say tank you once more to these pros who help rookies like me.
Old Aug 31, 2007 | 08:45 PM
  #37
Tim H's Avatar
Tim H
Iv'e been on this forum since 2000 and have read them all.
And when I need to really know something, I go to the Chevelle forum!
Old Sep 5, 2007 | 01:55 PM
  #38
lars's Avatar
lars
Don't just take my word for it. John Hinckley and I have been advocating the same facts for years. A very good paper written by John on timing and vacuum advance can be found here:
http://lbfun.com/Corvette/Tech/vette...101Article.pdf
I highly recommend everyone read this to gain a basic understanding of timing, vacuum advance, and the concepts of ported versus manifold vacuum.
For additional info, I have tech papers about how to set timing, vacuum advance control unit spec numbers, and engine vacuum concepts. Anyone interested in these papers can e-mail me for copies:
V8FastCars@msn.com
Lars
