Need help buying a cam
Ive tried emailing Comp on 'compcams@compcams.com' but I get no response. As I am in Australia, Im not interested in phoning at midnight and I cant order it over the web.
Does anyone have an email for Comp that gets checked? I also need some springs, locators and collets too.
Good Luck!
Crane catalog has a lot of step nose Gen-6
hydraulic roller cams, lifters, springs to match.
1996-2000 GEN-6, they have them from mild to
262/270 .050 duration.
www.Cranecams.com, phone #386-258-6174, fax #386-258-6167
You should post your specs here and you would at least get an answer from somebody that owns solid roller
I also agree about trying Summit Racing. Ask them...they'll give you good advice and they'll recommend which make cam, not just the individual grind spec.
We may not all agree on what stick to advise, but most of the opionions you'll get here do come from real world experience. If it's advice you seek, post your specs, such as bore, stroke, CR, rods, heads, intake..., and let us know what you want out of it
You might also consider Doug Herbert for roller cams ... top quality ... ALL herbert's rollers are billet ... for same or less $ than the others' cast rollers. Herbert also does step nose. Herbert's in NC USA 877-497-2787 www.dougherbert.com
-edit-much nearer you in OZ are 2 in Victoria & 1 in Queensland:
http://www.crowcams.com.au/templates...e-ChevBB.shtml
http://www.yellaterra.com.au/product...ance/index.cfm
http://www.romac.com.au/
Anyway here are my specs
70 coupe
Street driven weekend toy. I still want a decent idle, dont want to push it much past 6000RPM
3.7 rear TKO 600
4.470x4.25 (533)
320cc Pro Topline heads
10.2 comp
C454 dominator dual plane manifold
1050 annular 3 circuit progessive seconadries
2" doug Thorley headers, 3" exhaust
Wanting street solid roller and would run Crower lifters
I was thinking 11-771-8 or 11772-8
I need to get it on a stepped nose core, as a billet and with pressed on cast gear.
Duration @ .050 IN/EX: 241/249;Lift IN/EX: .625"/.625";LSA / ICL: 110/106;RPM Range: 2600-6200
Part #: 60213
UPC #: 090127619995
Hydraulic Roller; Rough idle, Serious street/strip camshaft. Needs 10.5:1 compression ratio, 3000–3500 RPM stall speed converter and 3.73 or better rear gears. Works well with plate style Nitrous systems or smaller Superchargers with up to 12 PSI boost.
Installation Notes
See the Master Lunati catalog for spring, retainer and keeper specifications or call Lunati Tech at (662) 892–1500
Features
Advertised Duration IN/EX: 292/300
Gross Valve Lift IN/EX: .625"/.625"
LSA / ICL: 110/106
Valve Lash IN/EX: Hyd/Hyd
Parts & Kits for 60213
P/N DESCRIPTION
72431LUN BBC Retro Fit Hydraulic Roller Lifters
73121 Valve Spring
74855LUN Beehive Valve Spring
75513 10 Degree Steel Retainer
76185LUN 10 Degree Titanium Retainer Beehive
77112LUN 10 Degree Valve Lock 3/8 W/Lash cap recess
73121K1LUN Spring Kit (73121,75513,77112)
74855K4LUN Spring Kit (74855,76185,77112)
93112 Timing Set 3 Keyway
93112 Roller Timing Set 3 Keyway
Technical Information
Cam Card for Part# 60213
http://crower.com
Eddie
http://crower.com
Eddie
I only have 434 ci and run 248/250 .685/.714 lift with 110 LSA It's a nice running machine that doesn't have the big thumpy sound at all.
So this Crane cam might fit 254/262 .714/.714 cast iron sleeved gear.
http://www.cranecams.com/?show=brows...tType=camshaft
8620 steel billet roller camshafts w/ cast iron gear. I see no reason
why it could not have a step nose. They will even make a
8620 steel billet hardface solid/flat tappit camshaft.
www.crower.com, ph # 619-661-6477 fax # 619-661-6466.
Cranes catalog says they have 80,000+ profiles available. Installs
Iron cam gears on to steel camshafts.
www.cranecams.com, ph# 386-258-6174, fax# 386-258-6167
They will even make you an industrial (diesel) cam.
I have a Doug Herbert Roller Cam, got good service and prompt tel support. No problems with cam, just what I wanted.
HiYa Jack!!
Bill
