Make sure you've bled all the air from the cooling system. This is very important. Put the car on ramps, jack up the front, put it on a hill (front end on the incline), whatever. Just get the front end up in the air. Then, open the radiator cap and start the engine. Let the car idle for 10-15 minutes. Then rev it a bit. Let it rev to about 2500, and keep it there for ten, maybe twenty seconds. This should do it. If necessary, top off the coolant.
If the car still runs hot, check your thermostat. The new thermostat I bought, to replace my "defective" old thermostat, was crap. I took a yeast thermometer, and I tested each thermostat in a pot of hot water, on my stove. I learned quickly that my old thermostat was just fine, and the new one was garbage.
Also, make sure your mixture is okay. Too much coolant will run hotter than less coolant. I actually run straight water, and my car runs in the 160's until I hit the freeway, where it sits at 200 rock solid.
check your lower radiator hose, it should have a spring in it and the hose should be firm. If it doesn't have the spring it can actually be sucked closed by the water pump which restricts flow=running hot
Signal Mountain is just outside the city limits of Chattanooga. You are 100 miles north of Knoxville and I am 100 miles south of Knoxville. Visit our Corvette club website http://www.rivercitycorvetteclub.com
:flag
Listen, I had the SAME problem. Come to find out, I was running 180 to 200 the whole time. For some reason, my gague just reads 20 degrees higher. There is a resister bolted to the back of the gague. Depending on the resister, your gague will read differently. It bugs me that it reads a little high, but I'd bet the house you have the same problem. Take it to a shop and have them shoot your radiator with an infared temp gun. I bet you're running fine!
Aftermarket temp senders seem to be hit or miss. I've had three in my car so far. The original one would show < 160 degrees in the middle of the summer. The first replacement would peg out at 260 degrees after about two minutes of driving. The third one is now indicating low as well.
I'm sure that these senders all have different resistive values. Knowing which one is correct is a mystery. I haven't had any overheating problems so I'm not sweating it (no pun intended) too much. :rolleyes:
2) Check fan clutch. When warmed up, turn the engine off and watch the fan. It should only spin 4-5 times before stopping.
3) Check your air dam under the nose and make sure it's there and intact.
If all these things check out, do the turkey thermo to varify the accuracy of the gauge. I don't know how much Water Wetter will help, but I run it in mine and I run 160* on a warm day in FL (160* stat). I credit this more to the seals, clutch, etc. though.
