What shocks are you using/skill level to change shocks
Old Aug 30, 2007 | 09:25 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default What shocks are you using/skill level to change shocks
Im thinking about changing the shocks on my 77. This will be a winter project. Just trying to get an idea of what shocks to replace with. Not looking for anything special...anything to watch out for with the front coils spring?
Now to the second part of the post, I would like to try to do this job myself. Anything special i need to know. Watch out for. Special tools... sersvice manual just says to remove bolts and reinstall bolts.
It sure looks simple.
Old Aug 30, 2007 | 09:29 AM
70vert's Avatar
70vert
Banned Scam/Spammer
If you have the skills necessary to change a tire, you can install new shocks. KYB makes good replacement street shocks.
Old Aug 30, 2007 | 09:41 AM
pws69's Avatar
pws69
Probably one of the more straight forward and easier jobs you will do on your C3!
I put Bilstein Sports on my 69 this year and the ride and handling improvements are amazing.
Old Aug 30, 2007 | 09:46 AM
ptroxx's Avatar
ptroxx
Love that 4 post lift you have, and the cars as well.. Thanks for the info.. I thought it looked simple.. If i had some air tools it would be even easier i think.
Old Aug 30, 2007 | 10:09 AM
Block_Head's Avatar
Block_Head
Do you happen to have a good link to some of these? I'm interested as well.
I would love some Bilsteins but they are just so expensive.
Old Aug 30, 2007 | 10:28 AM
427-390's Avatar
427-390
Get the GM Service Manual for your year C3. It will give you step by step instructions on how to remove/replace the shocks and will be useful for many other repairs on your car.
Old Aug 30, 2007 | 10:31 AM
Theiskell's Avatar
Theiskell
Old Aug 30, 2007 | 10:57 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
VB&P puts them on sale now and then.
Old Aug 30, 2007 | 11:06 AM
Block_Head's Avatar
Block_Head
So they are $300 instead of $500?
What makes the high dollar shocks better than the $20 shocks you can get at autozone?
Old Aug 30, 2007 | 01:25 PM
ptroxx's Avatar
ptroxx
Not sure if you look at the entire post. But like i said. The service manual only says raise vehicle. remove upper nut. remove 2 bolts. I was looking to see if there was something i was missing. Any tips,tricks,tools I needed.
It seems like an easy task. Do i do it with the tires on or off? Back rist then front?? one side or the other. I know i have to be cautious about jacking a C3 up. Any tips? For those of you that know me, Im kinda new here and limited on experiance so i only like to do things one time. So i ask a bunch of questions first this way im not half way in the job and i find out oh i needed that or ya know..
OK well im done.. Thanks for all the help you guys.
Old Aug 30, 2007 | 01:29 PM
Block_Head's Avatar
Block_Head
You can do it with tires on.
Jack car up and put it on jack stands.
Load suspension with jack.
Remove top nut and lower bolts and slide the shock out.
Reverse process for installation and repeat for other side.
Old Aug 30, 2007 | 02:35 PM
ptroxx's Avatar
ptroxx
AAAHHHH ... I see.. ok... I get ya.. Take the presure off... same for all 4??
Old Aug 30, 2007 | 02:40 PM
Block_Head's Avatar
Block_Head
You want the front tires supported a little but yeah no pressure.
When I did the back I just let the rears hang.
Old Aug 30, 2007 | 02:51 PM
427-390's Avatar
427-390
1. Doesn't matter which order you replace the shocks.
2. For the rear, it's best if you remove the rear tires, it allows for better access and removal (See #3 below). You can leave the front tires on when you replace the shocks.
3. With the rear tires off, place a jack carefully under the T/A or rotor and raise it just enough to take any downward pressure on the shock mount. It makes it easier to remove the nut holding the shock on.
4. Raise the front of the car and remove the front shocks as directed in the Service manual. The fronts are much easier to do then the rears.
5. Make sure your torque the nuts to spec.
6. You're done! Set the car down, drive and enjoy.
I used Delco Gas shocks. Cost was about $120 - $130.00 for a set. Shop around, you may get a better price. Car rides very nice after I replaced my shocks a few months ago.
Good luck.
Old Aug 30, 2007 | 03:31 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Bilstein Shocks from VBP
I recommend Bilstein shocks for just about any street application. They provide a good firm ride and great control without shaking your teeth out.
There are around a gazillion different shocks available for your Vette – I know because I have tried about half of them over the years while working at VBP. I keep coming back to Bilstein. They cost a little more but you really do get what you pay for.
Here is a link to the shock app for your Vette:
http://www.vbandp.com/detail.aspx?ID=920
And here is a link to Bilstein and their apps for you …
http://www.bilstein.com/mistore/ymm_...reYMM=storeYMM
Sincerely,
Alan G.
Vette Brakes & Products, Inc.
800-237-9991
Old Aug 30, 2007 | 03:48 PM
glenn64vette's Avatar
glenn64vette
Sincerely,
Alan G.
800-237-9991
Just to be sure, the Sport shock is firmer ( better spring control ) than the HD shock? I have heard different views on this. Thanks
Old Aug 30, 2007 | 04:12 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Installing Bilsteins on a C3 is one of the best investments you'll make in your car, as long as you get the correct set for your purposes. However, if preset valving isn't quite your cup of tea, I'd step up to the Koni DA's if you can't swing coil-overs.
To What shocks are you using/skill level to change shocks
Old Aug 30, 2007 | 04:23 PM
marshrat99's Avatar
marshrat99
with the KYB's and skill level. I'd rate changing shocks as about 4 beers ~ 1 per shock.
Old Aug 30, 2007 | 04:53 PM
ptroxx's Avatar
ptroxx
I have a 77 L48 stock auto. Im really just into driving my car. Its a driver not my only car but i love to drive her. I live in an area with great winding roads the car handles great right now. I just think 30 year old shocks need to be changed. I am kinda on a budget so.
But I love all the input. I was just looking on VB&P and they have some cools stuff......Thanks again everyone for the input
Old Aug 30, 2007 | 05:07 PM
72LS1Vette's Avatar
72LS1Vette
Buy some PB Blaster at any auto parts store and spray all of the nuts and bolts once a day for 2 or 3 days prior to changing the shocks. It will be a lot easier to remove the bolts after the PB works its magic for a couple of days.
Jacking the front of the car should be done with the jack at the point where the frame curves in just behind the front wheel well. DON'T JACK UP THE FRONT USING THE ENGINE CROSSMEMBER. It looks like a great place to put a jack and many Bubbas have used it but you will dent the h$ll out of the underside of the crossmember.
You don't have to worry about the front springs. The shocks are independent of them and are easily replaced.
Rick B.
