What shocks are you using/skill level to change shocks
Old Aug 30, 2007 | 06:03 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
SO where should i be jacking from??
Old Aug 30, 2007 | 06:33 PM
427-390's Avatar
427-390
For the front and rear, you can jack the car at the location of where you would if you were changing at tire ~ for the front, right behind the wheel well on the frame for each side. For the rear, right before the edge of the frame by the kickup.
BTW, my front crossmember has many "jack dents" in it from the previous owners. You can jack the car by the front crossmember, but you need to do it correctly using a brace between the front and back of the crossmember and placing the jack under the brace.
Old Sep 4, 2007 | 11:45 AM
glenn64vette's Avatar
glenn64vette
Originally Posted by glenn64vette
Just to be sure, the Sport shock is firmer ( better spring control ) than the HD shock? I have heard different views on this. Thanks
Here's the answer I found;
What is the main difference between the different settings?
Comfort setting shocks would be very much like the original shocks for your car. Heavy Duty will be somewhat stiffer and give your car a stiffer and more controlled ride. Sport setting shocks are 30% stiffer than Heavy Duty and are usually used with lowering springs for very hard driving and competition.
Old Oct 20, 2007 | 03:38 PM
ptroxx's Avatar
ptroxx
OK well I just replaced the shocks on the car.. Installed the gas a just KYB's......Man the car stands at least a few inches taller.. Im going to go for adrive here in a few and ill give everyone a report on how it drives......
No for installing the shocks .. It was a piece of cake... Nothing to it.. took a few hours but its done... And was fun to do.....Now im ready to go to the drive inn at foster freeze tonight,.
Thanks again for the help CF
Old Nov 8, 2007 | 07:35 PM
goatsandvettes's Avatar
goatsandvettes
Default Reading this post makes it sound easy
but I have 3 new shocks and one old one and the replacement for the old one was in the vette when I got it.. just now working way to back in (besides new brakes and calipers).. I wonder if bubba bubbaed something up and couldn't get the 4th shock off.. Any ideas what bubba could have bubbaed up... I'm going to try to change it this weekend after I go checkout a local car show.
