Have read several posts about the tach filter and it being normal for the needle not to always go back to zero. My question is: What is the tach filter for ???? Noticed also that several posts have recommended bypassing the filter. Maybe help to dampen eratic movement ?
The tach filter is a capacitance circuit used to filter out electrical spikes from the ignition so the tach will not react to the spikes and give erratic movement. It will still work without it but you might see some crazy readings that aren't true numbers.
The tach will not return to zero by design without the ignition on, mine does the same thing.
I was told once by a rebuilder to not use the filter because when it goes bad it ruins the tach board.Anybody else hear this?
That doesn't sound right, so if you don't use it you ruin the tach board right away by not having it in line?? Can't figure that one out, but who knows. Capacitors are commonly used in sensitive electronics to remove voltage spikes.
Thats what I thought also,so I called John at Red Line Gauges in Tn. and ask him to refresh my memory.I had called him about a week ago about changing a 69 mech.tach over to an electronic.He had told me not to use a filter on it.He also told me that what generally ruins a stock tach board is the "filter" when it fails.Is there more than 1 way for a filter to fail?Is the filter in this case a capacitor or does it just look like one? I Dunno. I will be talking to him again next week and I'll see if he'll give me more details.
I added a new tach filter to my GM 350 HO Deluxe crate engine because the I thought it was necessary for the tach to work right. I never ran the car without one. Should I try it? Or does the tach filter actually protect the tach and make it work right?
The tach filter is a capacitor as stated, its job is to isolate the DC component out of the tach circuit. DC will kill a tach, only the AC (ignition pulses) get coupled to the tach
I haven't run with a filter since I took it out cause my tach didn't work. But my msd ignition does not say I need one so I don't really have plans of putting one in. Gauge doesn't go crazy either.
It mounts to the intake, behind the carb & a little to the left. They came from the factory with a bracket wraped around it that is held down by a bolt........
That's an interesting statement....on standard electronics, a cap would normally be used to filter AC away from a DC circuit, I'm trying to figure this logic out in my head
Also, why DOES the tach needle stay at the last RPM reading when the key is turned off? My first thought was an energized circuit holding the needle, but wouldn't the energy eventually disipate?
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Guys,
The following are just my thoughts, as I don't have the schematics of the tachs and filters.
I would be inclined to continue using the filter. Rarely (okay, never) does GM go through the expense to build a part and then pay a lineworker to install it, if there wasn't a reason for it.
There's also a couple of technical reasons for a filter.
1) Isolation. The voltage at the (C-) tach line varies from zero volts to 200-400 volts during the ignition cycle. The tach circuit ideally should only need about 5-20 volts (pulses) to operate correctly. However, the C- voltage must not be loaded down, as this will affect the plug voltage/energy availability due to transformer action between the primary and secondary windings of the coil. Essentially, if you screw up the C- line, you can also screw up the high voltage (plug) line.
2) Filtering. There are multiple voltage spikes (ringing) on the tach line during the plug spark phase. Most tachs need just one spike per plug fire to read out accurately. A filter will help eliminate these multiple spikes entering the tach circuit. (Ideally, the tach should be designed to not need an external filter for ripple or voltage protection.)
